Thread: Can't delete multi leaders in drawing.
    2006-06
    17
    Default Can't delete multi leaders in drawing.
    Im seting up some drawings that already have multileaders that i dont want on there.
    I try to delete them but they stay. why is this?
    2005-07
    2,354
    Default Re: Can't delete multi leaders in drawing.
    Quote Originally Posted by kirkwilson_20 View Post
    Could be a number of reasons, is the leader on a locked layer?
    If not can you post a sample dwg file.
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    If it's Annotative, then there appears to be some problem with Annotative objects freezing up.
    This issue goes away when you close and open the drawing. It also goes away if you run an AUDIT (you can answer "No" to the prompt about fixing errors, and it will still free up "frozen" annotative objects).
    2008-02
    Southeastern, Connecticut
    4
    Thanks sinc, I was having the same issue. I could not move/modify/delete my dimensions that had Annotative properties. A simple save and open allowed me to delete them.
  1. Multi-Node Arrow Leaders
    By kkw in forum Revit Architecture - General
    Last Post: 2008-07-09, 09:28 PM
  2. cant delete multi leaders out of drawing
    By kirkwilson_20 in forum Hardware
    Last Post: 2008-01-11, 03:56 PM
  3. Multi-Leaders angles
    By Jeff Lyon in forum AutoCAD LT - General
    Last Post: 2007-09-10, 02:11 AM
