Results 1 to 7 of 7
Thread: Erection drawing (Anchor Bolt)
    2007-12
    3
    Cool Erection drawing (Anchor Bolt)
    1-Can someone tell if there is a way to have anchor bolt place in the drawing but NOT TO SCALE for erection drawing. Is the only way to have the anchor bolt shown (visually as we do in autocad) is to draw them by sketching ... hope not.
    I think that my system is working slow, I don't not if it's normal but we do only small building and i wonder why?
    P4 dual core 4 Gig 1.86 GHz Intell, 80 Gig, windows XP,
    thank you
    Marc
    2003-08
    Vancouver, BC Canada
    3,391
    Default Re: Erection drawing (Anchor Bolt)
    Welcome to the forums Marc.
    You can have your anchor bolt display pretty much any way you want. It depends on how you want to represent it.
    Does it need to be 3D or is the erection drawing a 2D view?
    Are you modelling all your anchor bolts? (Might be a clue to the performance issues)
    If you really need to model them you can create a family that has the 'real' thing as 3D geometry and turn that off in plan. You can then use symbolic lines to show the bolt in plan however you need to.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2007-12
    3
    I would rather have them in 2D, ( For the Fondation Drawing )
    My major problem is for the dimensionnig it seem to be impossible to do so not to scale, beside drawing them by sketching.
    Thank you
    Marc
    2003-08
    3,391
    As mentioned, you can create your base plate family and have the graphic display whatever you want. If your anchor bolt is a hex head you can have it show up as a square, a circle, a cross air, whatever. You can then dimension to that and still maintain the integrity of the actual modeled elements.
    BIMblog.ca
    2005-07
    Somewhere in the BIM world
    3,139
    Hey Marc, do you mean you want them bigger then regular size by "to do so not to scale"?
    Tu parles francais toi?
    2007-12
    3
    Question Re: Erection drawing (Anchor Bolt)
    Oui je parle français.
    ce que je veux dire c'est; Disont que les ancrages sont a 2 1/2" de l'axe ( dans la réalité), je voudrais pour mettre des cote de 2 1/2" mais qu'au plan les ancrages soient a +- 10" et aussi que le diamêtre des ancrages soient environs 4x plus grand.
    Au chantier, souvent les ancrages sont mal installé dû au fait que l'échelle 1/8 est trop petite, donc imagine 3/32" , et faire un plan a 1/4" ....
    Merci!
    2005-07
    3,139
    Quote Originally Posted by marcgendron40 View Post
    Good moi aussi. Voici le lien du forum francais en passant : http://forums.augi.com/forumdisplay.php?f=741
    Tu veux qu'elles soient a 2.5" mais la cote indique 10" ?
    Tu pourrais utiliser le Niveau de detail pour controler la taille.
  1. Anchor Bolt Block, One final Problem...
    By the_andyman17 in forum Dynamic Blocks - Technical
    Last Post: 2012-10-22, 07:48 PM
  2. Incorporating Erection Tolerances
    By hughrjt in forum AutoCAD Structural Detailing
    Last Post: 2010-03-24, 11:40 AM
  3. Erection drawings - possible to dimension to "nothing"?
    By Margarita in forum Revit Structure - General
    Last Post: 2009-08-06, 12:36 PM
  4. Structural - Dynamic Anchor Bolt
    By jeffc.engineer in forum Dynamic Blocks - Sharing
    Last Post: 2007-02-16, 09:33 PM
  5. NEED HELP With Anchor bolt layout
    By Borg in forum Land Desktop - General
    Last Post: 2004-07-07, 02:58 PM
