Results 1 to 9 of 9
Thread: Importing .pdf files
    100 Club WolffG's Avatar
    2003-06
    Syracuse NY, USA
    155
    Question Importing .pdf files
    Is there a way to import a pdf file and place it directly into a Revit drawing?
    Thank you
    I'm not interested what the architect has to say about his building.
    I'm interested what the building has to say about its architect.
    Member ed.76566's Avatar
    2004-10
    29
    Default Re: Importing .pdf files
    Use PhotoShop and open or import the PDF file, then save the PDF file as a JPG or BMP
    In Revit go to File/import/image and drop it where you want it. Remember the the scaling will be off and you will need to adjust the image using the resize tool between the mirror icon and group icon.
    You can also unlock the proportions, and/or move it to the forground or background etc.
    I would not depend on the PDF (now JPG) file to be more than a background because of x,y scaling, but it will help in fast proto layout.
    Ed
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,268
    If you have Adobe Acrobat you can open the PDF and do a "Save As" to JPG.
    AUGI Addict DaveP's Avatar
    2003-11
    St Paul, MN
    1,364
    In other words, no.
    Go back to AutoCAD? I'd rather lose my right arm!
    2003-12
    Victoria, BC
    1,268
    It is frustrating not to be able to import a PDF file. This is just Autodesk's none too subtle arm twisting to get you to use DWF. Someone should tell them the battle is over and they lost.
    2003-11
    St Paul, MN
    1,364
    Quote Originally Posted by Joef View Post
    . This is just Autodesk's none too subtle arm twisting to get you to use DWF. .
    I might believe that's true if you could import a DWF, but you can't bring in a DWF, either
    Just the markups
    2009-12
    Hi all,
    I'm brand new to AutoCad ('07) but comfortable with all Adobe, Illustraitor, Photoshop, etc.
    Is noted in this thread, you can't import a vector that turns into a spline. The only option is to place the vector and re-draw it.
    The problem is (I'm sure most of you have used Illustraitor at some stage) I can draw to my absolute satisfaction a complex vecto shape and have total control of the arcs, etc.
    I tried ( oh how I tried) to trace an image I drew in illustraitor ( then exported via pdf, dwg, dwx, everything!!!) but the spline tool is literally ****.
    But Given AutoCad is AutoCad, surely there must be a 'tracing' tool or something that I'm not aware of ??
    I have attached a pdf of a logo a drew in Illustraitor to demonstraite what I'm rambling on about... Any help would be greatly appreciated
    cheers
    James
    2001-12
    1,713
    You can't use DWF this way either (in Revit). This is just Autodesk's none too subtle way of being clueless.
    Gordon
    I could stop if I wanted to STHRevit's Avatar
    2008-01
    Perth WA
    294
    You can insert a pdf into autocad however.
    Perhaps do that and then insert the cad file into Revit?
    Certainly not ideal but a work around.
    Andrew
    STH BIM Manager
  1. 2010: Importing DXF files
    By jimmy.long in forum Inventor - General
    Last Post: 2011-07-27, 01:07 AM
  2. Importing DGN files
    By mikehaff in forum CAD Management - General
    Last Post: 2011-03-23, 02:47 PM
  3. Importing dwg files
    By thomasf in forum Revit Architecture - General
    Last Post: 2008-01-22, 05:27 PM
  4. Importing 3ds files
    By mf in forum VIZ - General
    Last Post: 2005-10-18, 02:26 PM
  5. Importing Dwg Files...
    By hkeller in forum Revit Architecture - General
    Last Post: 2005-03-04, 03:48 PM
