Results 1 to 6 of 6
Thread: Help for Stepped footing of wall
    2005-09
    VARANASI in India
    290
    Default Help for Stepped footing of wall
    I want to make stepped footing for wall foundation. I tried footing from structural as well as stacked, and furred wall, but i need stepped footing. Like if concrete footing is 3 ft wide, then 1st layer of brick footing is 2ft wide for 6 inch height, its upper layer 1.75 ft wide & 8 inch heigh & so on for 4 to 5 steps. The wall will stand over this. It is the treaditional old system of wall making. Can any one help me to make it ?
    Lallan Ji
    All AUGI, all the time eddy.lermytte's Avatar
    Belgium
    554
    Default Re: Help for Stepped footing of wall
    A wall reveal.
    2005-09
    VARANASI in India
    290
    Thanks Eddy for reminding me the basic Sweep command
    2004-06
    Memphis TN area
    6,719
    I would probably do it as a hosted solid sweep profile (not reveal) and add it into your foundation wall type.
    I'm not sure how a reveal could make that work.
    AERC, PLLC
    Hernando, Mississippi
    2005-09
    VARANASI in India
    290
    Ya Patricks I did the same. i edited a wall family structure, click the sweep button, loaded my footing profile, add material, set the ofset for positioning the footing and that is done. My footing profile added to the wall type.
    Lallanji
    2005-09
    VARANASI in India
    290
    Here I created wall footing by adding 2 sweeps at botom of walls with 2 profiles. Is this a right method ? Any other easy method ?
  1. STEPPED WALL FOOTING
    By dotrvt in forum Revit Structure - General
    Last Post: 2011-10-25, 08:02 PM
  2. stepped footing
    By jakob_k in forum Revit Structure - General
    Last Post: 2010-06-14, 03:20 PM
  3. overlapped stepped footing please
    By ddenton in forum Revit Architecture - General
    Last Post: 2010-04-14, 07:27 PM
  4. Rebar in Stepped footing
    By jkh in forum Revit Architecture - Families
    Last Post: 2009-12-07, 08:35 PM
  5. Joining Material in Stepped Footing
    By ppirtle in forum Revit Structure - Families
    Last Post: 2008-12-19, 03:50 PM
