Thread: Multiple versions
    2005-10
    Texas
    187
    Default Multiple versions
    people here are running many versions of ACAD. The versions running here are ACAD 2004, 2007, LT2004 and LT2007. Is this mix of software wise? Would it be better to just have 2007 across the board? Are there obstacles that could potentially slow production? The habit here is to save files in the default format. I have thought of setting the default on all of installtions to 2004, since 2007 is backward compatible. But there is a user here who says that there are elements she uses in drawings that would not appear in the files if saved in the 2004 format. What kind of 2007 elements would be absent in 2004?
    2007-06
    271
    Default Re: Multiple versions
    The elements will appear, they'll just be broken down to different elements, like a multi-leader with two leaders would be broken down to two leaders and an mtext item.
    We save down when sending files to other consultants who need a 2004 file format, we've never had one complaint about the 2007/2008 specific items.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Quote Originally Posted by Harold Pei Jr View Post
    Actually, the multi-leaders will come in as proxy graphics. They are not editable by the lower version. I have this problem with 2007 opening a drawing saved down to 2004 format.
    2005-10
    Texas
    187
    There are many flavors of ACAD here. One employee, who is using one of the newer versions of ACAD, refuses to save in an earlier version, saying that there are things she uses that will not appear otherwise. After what you indicated, I understand what she was saying. But is that by itself enough to refrain from saving to an earlier format?
    150700
    3,439
    Quote Originally Posted by wesley.chin View Post
    Depends.. we use AutoCAD Mechanical07 here, and when opened in LT07, weld callouts do not appear. There are no object enablers available to fix this. We ended up getting a full version of the software for our "document person", so she could open our drawings, and work in them.
    I guess it depends on what you do/what you need.
  1. 2015: Any need to maintain multiple versions of Navisworks?
    By david_spehar in forum NavisWorks - General
    Last Post: 2015-06-04, 05:15 PM
  2. Multiple Versions
    By randyspear in forum CAD Management - General
    Last Post: 2010-06-07, 06:20 AM
  3. Multiple AutoCAD Versions installed
    By rbrekke7560 in forum Software
    Last Post: 2010-03-08, 06:06 PM
  4. Upgrading Through Multiple Versions
    By phyllisr in forum Revit - Platform
    Last Post: 2008-07-07, 03:22 PM
  5. Error handling for multiple versions
    By mcoffman in forum VBA/COM Interop
    Last Post: 2006-09-08, 03:36 PM
