Results 1 to 10 of 10
Thread: can't select objects
    2003-11
    281
    Default can't select objects
    I've tried pickadd, pickauto, pickfirst, highlight, clear selection set lisps, cycle on/off I don't have multiple drawings open.
    I have ACAD 05 and my object selection is acting up. i can't select certain objects at random times. if i envoke any command first i can pick them but i am so used to selecting and then doing the command.
    it works fine sometimes and then other times it just stops working. i don't have to exit the drawing to get it to work but this is slowing me down. (it is any file i open and other users aren't having this problem with those files)
    i see others have had this problem but i haven't found a solution that works yet.
    please help?
    thanks
    150700
    3,421
    Default Re: can't select objects
    Quote Originally Posted by randyspear View Post
    please help?
    thanks
    Hmm.. have you checked PICKAUTO and PICKDRAG?
    2003-11
    281
    yes. sorry i thought i had them all listed there.
    2007-07
    Jo'burg SA
    4,344
    I've had the same problem a few months ago, but on AC2008. I've had to insert the drawing into a new clean drawing and explode, only then it worked.
    Someone explained that it was something to do with entities drawn on layer 0 or Defpoints, and these layers frozen / locked. I'm not sure how that works though?
    All AUGI, all the time jmctamney's Avatar
    Blue Springs, MO
    656
    Go to your selection tab in your options. Under selection modes see if Noun/verb selection is checked
    2003-11
    281
    Quote Originally Posted by jmctamney View Post
    this is the pickfirst sysvar and it is checked or set to (1).
    as for "irneb", when layer 0 is off or frozen you cannot pick anything on defpoints layer. (no need to move to a clean dwg.) This is not the case here.
    anybody else?
    150700
    3,421
    anybody else?
    Try a command line purge (-purge) and purge all RegApps.
    Blue Springs, MO
    656
    please help?
    thanks
    So what your saying is...it will randomly act as if pickfirst is set to '0'. Sounds like something is messing with your variables. Can you give some specific commands you are using?
    2003-11
    281
    Quote Originally Posted by BrenBren View Post
    that didn't work either.
    thanks though.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    1,901
    We have had issues with drawings getting set to perspective view. I think it gets done inadvertently when using 3dorbit. Try this:
    Dview
    Return (select objects)
    Points
    0,0,0 (target)
    0,0,1 (camera)
    Jeff Paulsen
  1. Cannot Select ALL Objects
    By kim.jinsu in forum AutoCAD General
    Last Post: 2010-04-06, 02:39 PM
  2. Is there a way to un-select objects?
    By Colquhoun in forum Revit Architecture - General
    Last Post: 2007-03-27, 02:49 PM
  3. Can only select objects once.
    By cadmecheng in forum AutoCAD General
    Last Post: 2006-11-02, 11:11 AM
  4. Can not select objects
    By cconfer in forum AutoCAD General
    Last Post: 2006-10-23, 04:35 PM
  5. Replies: 3
    Last Post: 2004-06-14, 06:50 PM
