Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: acaddoc.lsp?
    2007-02
    Lost?
    118
    Default acaddoc.lsp?
    I am a beginner when it comes to lisps. Could someone tell me how to create this file (title) so that everytime I open a drawing all of my settings will be set to default? The reason I need this done is because every once in a while I will open a drawing and the FILEDIA needs to be reset to 1.
    Please shed some light on this subject.
    150700
    3,439
    Default Re: acaddoc.lsp?
    Quote Originally Posted by Spanky View Post
    If you already have an acaddoc.lsp file created, simply add, at the end the following:
    (setvar "filedia" 1)
    If you don't have it created, open notepad, put the above statement in a text document (not word, use notepad), and save it as acaddoc.lsp. Make sure it's location is in your search path.
    Also, note, if your filedia (or any other variable) is changing while in a drawing (mostly due to an errant lisp program), this isn't going to help for that particular drawing. It runs everytime you open a drawing, but only upon opening it. Once a variable is changed while in the drawing, this won't change it back until the next time you open it.
    2007-02
    Lost?
    118
    Quote Originally Posted by BrenBren View Post
    So I would have to add a file to the Support File Search Path? And this would point to the folder which contains the notepad file that says (setvar "filedia" 1). This is what I have done and it does not seem to be working.
    150700
    3,439
    You should be adding the folder where your acaddoc.lsp file is located in your support file search path (SFSP)
    You should also search for other copies of acaddoc.lsp
    AutoCAD is looking for acaddoc.lsp, it goes through the SFSP from top to bottom, and as soon as it encounters acaddoc.lsp, it loads it. If your changes were made in a different copy of acaddoc.lsp, they won't load.
    2005-06
    in the upper right corner
    3,508
    You may not have an acaddoc.lsp (you or someone else would have to create it), but if you do, you can find it's location by typing on the command line:
    (findfile "acaddoc.lsp")
    It will return the path of where it lives.
    As Brenda mentioned, it should be where AutoCAD can find it, mine lives here:
    "C:\\Program Files\\Autodesk Architectural Desktop 2006\\Support\\acaddoc.lsp"
    This path is already set in my support folders under options.
    2007-02
    Lost?
    118
    There was not an acaddoc.lsp file before i put one in there. So the next question is how do you add a file?
    150700
    3,439
    How do you add a file where?
    You have created an acaddoc.lsp file (using a text editor, like notepad, correct?)
    You need to add the folder where you've placed your acaddoc.lsp to your SFSP. You can do this in your options dialog under the File tab.
    Is that what you are asking?
    2007-02
    Lost?
    118
    I already did this and it didn't work.
    Created lsp file in note pad.
    Saved it to C:\Program Files\Autodesk Civil 3D 2007\Acaddoc.lsp
    Went into my sfsp. Added a search path. Which would point to C:\Program Files\Autodesk Civil 3D 2007\Acaddoc.lsp
    I opened an acad session (civil 3d), set the filedia to 0, then closed and reopened. It opened with it still set to zero.
    150700
    3,439
    When you are in your session, type (findfile "acaddoc.lsp") and tell us what it returns.
    2005-06
    3,508
    Make sure you have the "startup" function listed at the beginning:
    (defun s::startup ()
        (SETVAR "OSMODE" 703)
        (SETVAR "REGENMODE" 1)
        (SETVAR "GRIDMODE" 0)
        (SETVAR "SNAPMODE" 0)
        (SETVAR "LIMCHECK" 0)
        (SETVAR "BLIPMODE" 0)
        (SETVAR "PLINEGEN" 1)
        (SETVAR "UCSICON" 1)
        (SETVAR "MIRRTEXT" 0)
        (SETVAR "BINDTYPE" 1)
        (SETVAR "DIMASSOC" 2)
        (SETVAR "VISRETAIN" 1)
        (SETVAR "FILEDIA" 1)
        (SETVAR "ATTDIA" 1)
        (SETVAR "ATTREQ" 1)
        (SETVAR "INSBASE" (list 0.0 0.0 0.0))
        (SETVAR "HPASSOC" 1)
        (PRINC)
    This is some of what my acaddoc.lsp looks like
  1. where did acaddoc.lsp go?
    By cwjean76 in forum AutoLISP
    Last Post: 2010-09-22, 08:28 PM
  2. acaddoc.lsp
    By ted.evans in forum AutoCAD General
    Last Post: 2010-01-22, 07:10 PM
  3. AcadDoc.lsp
    By Shizzjr in forum AutoCAD General
    Last Post: 2008-03-28, 11:19 PM
  4. ACADDOC.LSP
    By dbrownson in forum AutoLISP
    Last Post: 2008-02-06, 04:52 AM
