Thread: Explode(?) field after block insertion
    2007-02
    Default Explode(?) field after block insertion
    Is there a way to explode or otherwise disable a field after the block it is in has been placed in the drawing? I want to use filename and createdate fields in my title block but our ERP system automatically saves the file under a new name once it is uploaded and when you save a copy of the file out of the system in order to rev it, the creation date changes.
    I want to auto populate these things but I can't have them changing on me later.
    Thanks for your help
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: Explode(?) field after block insertion
    Quote Originally Posted by dweber.134794 View Post
    if you absolutely have to: click on the field in the editor, right click, select "convert field to text"
    S&D DB Sharing Forum
  1. Table Cell Reference Field Lost on Block Explode
    By pracslipkerm in forum AutoCAD Fields
    Last Post: 2013-12-11, 02:30 AM
  2. Blocks explode on insertion
    By dkuhn in forum AutoCAD General
    Last Post: 2013-03-11, 01:30 PM
  3. Replies: 3
    Last Post: 2012-08-03, 12:21 AM
  4. cannot explode block
    By LynNV in forum AutoCAD General
    Last Post: 2011-07-22, 07:13 PM
  5. Loose dynamic states from sub block after insertion into master block
    By ANRCREATIONS in forum Dynamic Blocks - Technical
    Last Post: 2005-11-15, 02:41 PM
