Thread: Scale List Units Metric / Imperial
    2005-07
    2,356
    Default Scale List Units Metric / Imperial
    Probably more Autocad related rather than ACA but any idea why I have a drawing with units set to metric but the Viewport Scale List and Annotation Scale List shows up in imperial?
    2005-07
    2,356
    Default Re: Scale List Units Metric / Imperial
    It only happens with dwg files received from a Surveyor that we use, see attached as an example.
    2003-03
    Philadelphia, PA
    2,392
    Quote Originally Posted by Steve.Sanderson(UK) View Post
    That drawing had the Measurement system variable set to 0 (Imperial) and not 1 (Metric). Unfortunately, simply changing the value of Measurement to 1 is not enough. You will also have to run ScaleListEdit and reset the list to the default values.
    2005-07
    2,356
    Quote Originally Posted by dkoch View Post
    Thanks David you're a star, that's been bugging me for quite some time
  1. Switching units (metric to imperial) in families
    By argman in forum Revit Architecture - Families
    Last Post: 2024-01-30, 02:34 PM
  2. Change Units From imperial to metric
    By GrD in forum AutoCAD Structural Detailing
    Last Post: 2013-10-12, 02:14 PM
  3. HELP - Changing Revit units from imperial to metric
    By m.fabb425767 in forum Revit Architecture - General
    Last Post: 2012-01-21, 04:30 PM
  4. Converting a Survey from Metric to Imperial Units
    By marble in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-11-22, 02:11 PM
  5. Imperial Units to Metric Units
    By BASE in forum Revit Structure - General
    Last Post: 2009-12-03, 11:25 PM
