Results 1 to 10 of 11
Thread: Erasing a selection set name
    2003-10
    706
    Default Erasing a selection set name
    Here's a quicky. How do you release or erase a selection set once it is created? I want to use:
    Set sset = ThisDrawing.SelectionSets.Add("ss1")
    where ss1 is the name of the selection set but after the objects are used I want the user to be able to select another selection set with the same name to keep working but an error keeps coming up stating the selection set (ss1) already exists. Help!
    2002-02
    Saskatoon, SK Canada
    23
    Default Re: Erasing a selection set name
    Hi williams.60073.
    When you are done with the selectionset just call:
    sset.Delete
    Or, if you've lost the reference to sset call:
    ThisDrawing.Selectionsets("ss1").Delete
    Hope this helps
    Warren M
    2003-10
    706
    The help file suggests that everything in the selection set will also be deleted if I do that. Is that true?
    From the help file:
    "The Delete method deletes a selection set and all items in the selection set. Neither the selection set, nor the items previously in the selection set will exist after a call to the Delete method."
    Turlock, CA
    6,409
    You don't have to worry about getting rid of ss's, they're only temporary in the dwg. When you close the dwg, the ss collection is cleared. All you have to worry about is when creating a new one, you don't try to use a name that already exists or you'll get an error. The usual method of avoiding runtime errors is to error trap. Try to create the set with the name you want. If it errors, reuse the name.
    Public Function AddSelectionSet1(SetName As String) As AcadSelectionSet
    ' This routine does the error trapping neccessary for creating selection sets.
        On Error Resume Next
        Set AddSelectionSet = ThisDrawing.SelectionSets.Add(SetName)
        If Err.Number <> 0 Then
            Set AddSelectionSet = ThisDrawing.SelectionSets.Item(SetName)
        End If
    End Function
    Once you have the ss, use ss.Clear to start fresh.
    C:> ED WORKING....
    LinkedIn
    2002-02
    23
    From the AutoCAD ActiveX and VBA Reference for 2005:
    "Delete: The Delete method deletes a selection set object, but not the objects in the selection set. While the selection set itself will not exist after the call to the Delete method, the items previously in the selection set will still exist. "
    Warren M
    Quote Originally Posted by williams.60073
    From the help file:
    2004-06
    42
    Quote Originally Posted by eljobe
        End If
    End Function
    nice, better than what i used to clean before create
    Public Sub limpiadibu(x As Variant)
    Dim TestForSelSet As AcadSelectionSets
    Dim Cntr As Long
    Set TestForSelSet = AutoCAD.Application.ActiveDocument.SelectionSets
    If AutoCAD.Application.ActiveDocument.SelectionSets.Count > 0 Then
    For Cntr = 0 To AutoCAD.Application.ActiveDocument.SelectionSets.Count - 1
    If TestForSelSet(Cntr).Name = "SS2" Then
    AutoCAD.Application.ActiveDocument.SelectionSets.Item("SS2").Delete
    End If
    Next Cntr
    End If
    End Sub
    Turlock, CA
    6,409
    Even if you were going that route, remember that ss's are in a collection and you can ForEach those.
    Function AddSelectionSet (name As String) As AcadSelectionSet
       Dim ss As AcadSelectionSet
       For Each ss In ThisDrawing.AcadSelectionSets
          If ss.Name = name Then
             ss.Clear
             Set AddSelectionSet = ss
          Else
             Set AddSelectionSet = ThisDrawing.SelectionSets.Add name
          End If
    End Function
    C:> ED WORKING....
    LinkedIn
    Turlock, CA
    6,409
    Forget that, that's going to try and add an ss for each ss in the collection. It will error the next loop. But I just wanted to show you how to iterate with For Each.
    C:> ED WORKING....
    LinkedIn
    AUGI Addict sinc's Avatar
    2004-02
    Colorado
    1,986
    What about this statement from the documentation?
    Attempting to manage a large number of selection sets simultaneously is not recommended. An AutoLISP application cannot have more than 128 selection sets open at once. (The limit may be lower on your system.) When the limit is reached, AutoCAD refuses to create more selection sets. Keep a minimum number of sets open at a time, and set unneeded selection sets to nil as soon as possible. If the maximum number of selection sets is reached, you must call the gc function to free unused memory before another ssget will work.
    2003-10
    706
    I guess that is talking about in the current open drawing. As soon as another is opened the selection set count is reset.
    From the help file:
    Also, my documentation about deleting the entities in the selection set came from an old help file. I guess they changed that feature after Acad 14?
  1. Erasing everything outside a boundary
    By Stephen.Walz in forum AutoLISP
    Last Post: 2019-05-13, 01:28 AM
  2. Erasing Design Options
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2010-04-26, 02:33 PM
  3. Erasing Alignment Labels
    By jpaulsen in forum AutoCAD Civil 3D - General
    Last Post: 2007-05-11, 03:03 PM
  4. erasing titles
    By tect75 in forum Revit Architecture - General
    Last Post: 2006-03-20, 03:28 PM
  5. Phase Erasing?
    By gregcashen in forum Revit Architecture - General
    Last Post: 2003-09-18, 07:21 AM
