Thread: Underground parking with topography on top
    2008-01
    2
    Default Underground parking with topography on top
    Is there any way to use topography with a pad, Underground parking and have above the pad some more topo to layout paths and driveways. Sort of like a cave with entry ramps from the street level.
    thanks for any help
    J
    All AUGI, all the time Alex Page's Avatar
    2004-03
    Wellington, New Zealand
    822
    Default Re: Underground parking with topography on top
    nope!
    I just use the 'create' button to create a bit of topography to go on top....so
    Cut the topography away using the pad tool
    Create new topography using solids and the 'create' tool
    2006-03
    London, UK
    810
    I don't bother with Pads, for this reason. I cut a hole in the Toposurface where I want the building to penetrate, and turn the visibility of topography off in in any plans underground.
    2007-03
    Melbourne, Australia
    278
    As already stated you cant set a depth for topography to start at, you can however control the depth that it is shown in section and elevation (this is the poche depth)
    You could either do as suggested by tomnewsom and just have the topo at the level required (at a phase which is suitable, so that it is only there for final earthworks stage) and then you would need to turn off the hatch in any sections\elevations which are in this final earthworks stage
    Another option is to create your own surface as an in-place family but I think this method is more work that necesary, it is explained in more detail in this thread http://forums.augi.com/showthread.ph...raphy%2Btunnel
  1. 2013: Underground Tunnel through topography
    By tbird.226056 in forum Revit Architecture - General
    Last Post: 2015-05-29, 09:22 PM
  2. Replies: 1
    Last Post: 2014-04-21, 10:29 PM
  3. Creating an Underground Parking Garage...
    By Mromita in forum Revit Architecture - General
    Last Post: 2009-02-13, 12:25 AM
  4. Parking schedule with square feet per parking space
    By Archman in forum Revit Architecture - General
    Last Post: 2006-11-20, 07:11 AM
  5. Parking Spaces--Parking Component or Site Componenet
    By Eric Stewart in forum Revit Architecture - Families
    Last Post: 2003-11-07, 09:32 PM
