Results 1 to 8 of 8
Thread: Flip Dimension Text
    2005-02
    13
    Default Flip Dimension Text
    Is it possible to flip dimension text?
    2003-08
    Vancouver, BC Canada
    3,394
    Default Re: Flip Dimension Text
    Check out the read convention settings in the type parameters of the text style
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2005-02
    13
    Dimitri,
    Thanks for the quick reply. The Read Convention did work on one set of dimensions but not on another. I failed to tell you one thing. I had rotated the view 90 degrees clockwise from its original view. Maybe thats why the former horizontal dimensions that are now vertical will not flip to the other side of the dimension string?
    See Attached.
    All AUGI, all the time jetisart's Avatar
    2004-10
    Sunshine Coast, QLD, Australia
    607
    In version 5 and 5.1 of Revit you could have a dimention text above or under the dimension line and - if I remember correctly left or right oriented. I.e. it could serve any situation. And it was good. For whatever reason this functionality has been removed from Revit and it's a great pity. I wrote several times already about this - to no avail.
    2002-12
    681
    Quote Originally Posted by jetisart View Post
    Programmers must have had a reason for doing this ... ... I hope they didn't anticipate enhancements back then and they still haven't materialized ... ... so it has gone unfixed. Wouldn't surprise me if this is the case.
    I for one - am anticipating text and dimension enhancements in R2009. Perhaps things will be fixed.
    2003-04
    Irvine, CA
    6,778
    ...In version 5 and 5.1 of Revit you could have a dimention text above or under the dimension line and - if I remember correctly left or right oriented...
    My memory must be fading, I don't remember this at all.
    2004-10
    607
    Quote Originally Posted by Steve_Stafford View Post
    Your memory must be fading...
    2003-04
    Irvine, CA
    6,778
    Guess so...I'll have to pull out my 5.0 and 5.1 discs and take a trip down memory lane sometime.
  1. Dimension Text To Flip When Rotated View
    By designassocarch in forum Revit Architecture - General
    Last Post: 2008-01-24, 06:57 PM
  2. Update Dimension text so it reads correctly ie Flip it
    By rustific in forum AutoCAD General
    Last Post: 2007-02-14, 01:53 PM
  3. Flip Text and flip justification at the same time
    By jakob_k in forum Dynamic Blocks - Technical
    Last Post: 2007-01-17, 06:43 PM
  4. Replies: 6
    Last Post: 2006-04-07, 01:41 PM
