Is there a way to put casework in an interior elevation vs. having to put in it in plan view only? Some kind of parameter maybe?
if it's wall based you should be able to place it in elevation. If it's a level based (or non-based) Revit doesn't know how far you want it from the cut plane of the view.
You can, however, place 1 piece of casework in plan and then move, copy, and change it in elevation...
Good call. Thanks.
Come to find out the domestic wall cabinets are wall based and the base cabinets are floor based. Go figure.
