carlos9t
Before creating a roof there is an option next to your overhang distance, I do not have Revit in front of me now, but I think is called attached roof to the core structure or something like that, you need to check this option if you want your bearing point be in the structure of the wall and no in the finishes..
In your case looks like you did not check this option. Just select your current roof, edit the sketch, select all the skecth lines and check this box (again next to the overhang distance).
Good luck.
