I have to add a new sheet at the beginning of one of my subsets (one dwg with multiple tabs). Since I have fields in the title blocks referencing the sheet set I figured I could:
1. renumber my layout tabs (1-10)
2. remove the last sheet in that subset and then go to properties and redirect each sheet to the correct file/layout tab.
3. import the last layout tab as a sheet and rename and number accordingly.
this doesn't work. when i try to import layouts that have been previously removed it says they are unavailable for import. Also, when i create new layout tabs, they do not show at all when trying to import them.
I have tried doing this while the drawing in question is open and closed and i have done a "resave all sheets".
what am i doing wrong?
