Results 1 to 7 of 7
Thread: Annotative Text on moves?
    2007-06
    286
    Default Annotative Text on moves?
    I've noticed that when moving or selecting annotative text, that it seems to show every text scale associated to it. Is there a way so it doesn't do that. It really becomes irritating when trying to edit things and you get this large text that isn't even displayed on the screen.
    Thanks.
    2007-08
    Fairbanks, AK
    136
    Default Re: Annotative Text on moves?
    This is controlled by the variable "annoallvisible". Default value is 1, if you set it to 0, you will only see the current scale.
    From the help file:
    Hides or displays annotative objects that do not support the current annotation scale
    Only annotative objects that support the current annotation scale are displayed
    All annotative objects are displayed
    The ANNOALLVISIBLE setting is saved individually for model space and each layout.
    NoteWhen ANNOALLVISIBLE is set to 1, annotative objects that support more than one scale will only display one scale representation.
    Hope this answers your issue.
    Bill
    2007-06
    286
    Unfortuantely that doesn't work. I was aware of the variable, but it was a good thought. It seems that with it turned on or off, when going to move anything, all scale appear. This might be a request that has no solution.
    2006-12
    Big "D"
    3,709
    Use this variable.
    selectionannodisplay
    This controls whether alternate scale representations are temporarilly displayed in a dimmed state when an annotative object is selected.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2007-06
    286
    Quote Originally Posted by dzatto View Post
    Use this variable.
    Perfect. Thats exactly it. Thanks a bunch!
    2006-12
    Big "D"
    3,709
    Quote Originally Posted by guitarchitect7 View Post
    It works for me. I set selectionannodisplay to 0, and only the current scale show up whether I'm just selecting it or moving it.
    AHHHHHHH never mind!!!
    AUGI is double posting stuff again.
    You're welcome!
    RevitForum.org
    2007-08
    Fairbanks, AK
    136
    Thanks for the information as well. I'll incorporate that variable into the startup routine.
  1. Text moves when I edit it
    By JRBOURNE in forum ACA General
    Last Post: 2012-06-07, 05:18 PM
  2. 2011: annotative text and annotative block failure
    By kuruczregina in forum ACA General
    Last Post: 2012-03-25, 06:56 PM
  3. DIM TEXT MOVES
    By wroebuck in forum AutoCAD Annotation
    Last Post: 2008-06-28, 12:59 PM
  4. mleader: text moves away from leader
    By pbrumberg in forum AutoCAD Annotation
    Last Post: 2008-04-11, 02:48 AM
  5. Parametric Titleblock that moves text
    By dpollard909366 in forum Revit Architecture - General
    Last Post: 2006-06-14, 05:31 PM
