Results 1 to 7 of 7
Thread: Text backwards after Mirror Command
    All AUGI, all the time gfreddog's Avatar
    2003-07
    Pequannock NJ US of A
    641
    Default Text backwards after Mirror Command
    Cryptic enough title for this post?
    I have recently upgraded to AutoCAD MEP 2008 (no Express Tools). And I need to find out if there is a setting or Sysvar that corrects the text in a block to read correctly after you mirror a block?
    What happens is, I mirror a block with text in it and it is now backwards. It happens in a block with text or a block with attributes.
    In previous versions AutoCAD 2004 & 2007 it flipped without a problem but they were machines that were previously set up by others.
    Any ideas?
    George V. Fournier Jr., CTS
    Sr. Sales Engineer - Autodesk Product Design Suite Premium 2014
    2006 AUGI DAWG (7th) - NJ AUGI Camp
    Volunteer Firefighter since 1985 & Bagpiper Wanna-be
    With the freedom of expression comes great responsibility
    2005-06
    in the upper right corner
    3,021
    Default Re: Text backwards after Mirror Command
    Quote Originally Posted by gfreddog View Post
    Any ideas?
    The variable is "mirrtext" you want it set to "0" (off).
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    2003-07
    641
    Thanks that helped with the blocks with Attributes.
    But, blocks with plain text still mirror backwards. Or am I expecting something that never worked in the first place, after all it is monday and my brain is celebrating the Giants win!?!
    2005-06
    3,021
    But, blocks with plain text still mirror backwards. Or am I expecting something that never worked in the first place, after all it it monday?
    I believe that plain text in a block will stay mirrored no matter what.
    Happy Monday!
    Ted
    2003-07
    641
    Happy Monday!
    Yeah you're right... coffee set in... found the following in the Help Section
    MIRRTEXT affects text that is created with the TEXT, ATTDEF, or MTEXT commands; attribute definitions; and variable attributes. Text and constant attributes that are part of an inserted block are reversed when the block is mirrored regardless of the MIRRTEXT setting.
    2015-11
    Jo'burg SA
    4,512
    So you could of course convert all text in a block into Attributes, simply for this reason. Although you might have difficulty with the MText objects. You could try MultiLine Attributes, but that's another kettle of worms.
    2015-11
    Jo'burg SA
    4,512
    You could circumvent this by adding a Flip Parameter to the block, then in stead of mirroring the block, you change its Flip state.
    For example insert the attached as a block into your drawing. It shows TEXT, MTEXT and the 4 variants of ATTRIB.
    • If you use the mirror command, only the ATTRIB entities mirror according to the MIRRTEXT sysvar. However if you ever use the ATTSYNC or BATTMAN Synchronize they get turned as per normal text would.
    • If you use the Flip State (Arrow on 2nd line) to "mirror" the block, the text and the fixed ATTRIB's mirror correctly. The movable attributes don't move at all, even after using ATTSYNC.
    So if you only want text or fixed attributes, then use a flip-state. Otherwise your block has to have Attributes only, or you create a mirrored version of the block.
  1. 2013: Flip action without flipping text backwards
    By Darren Allen in forum Dynamic Blocks - Technical
    Last Post: 2014-10-14, 08:38 PM
  2. 2013: Mirrored Text is backwards
    By Darren Allen in forum AutoCAD General
    Last Post: 2014-10-08, 01:45 PM
  3. Backwards model text?
    Last Post: 2007-05-30, 03:34 AM
  4. Mirror command
    By kornackiph in forum Revit Structure - Wish List
    Last Post: 2007-02-01, 02:50 PM
  5. Replies: 8
    Last Post: 2006-11-20, 01:45 PM
