Sorry, again I'm NOT using the block editor. I define a BlockTableRecord and add it to the BlockTable of the database. Something like this...
Dim Blocks As BlockTable
Dim ObjId As ObjectId
Dim Block As BlockTableRecord
Dim Trans As Transaction
Dim BasePoint As Point2d
Trans = Database.TransactionManager.StartTransaction
Try
Blocks = Trans.GetObject(Database.BlockTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False, False)
ObjId = Blocks.Add(New BlockTableRecord)
Block = Trans.GetObject(ObjId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite, False, False)
Block.Name = "MyBlockNameHere"
Block.Units = Autodesk.AutoCAD.DatabaseServices.UnitsValue.Undefined
Block.BlockScaling = Autodesk.AutoCAD.DatabaseServices.BlockScaling.Uniform
Block.Comments = "This block is generated automatically and should not be edited."
Block.Explodable = False
Trans.AddNewlyCreatedDBObject(Block, True)
' Code to add geometry goes here...
' Need some other code here to add dynamic properties???
Catch ex As Autodesk.AutoCAD.Runtime.Exception
Application.ShowAlertDialog("CreateBlock" & vbNewLine & ex.ToString)
Block = Nothing
Trans.Abort()
Finally
Trans.Dispose()
Trans = Nothing
Database = Nothing
End Try
