Thread: Deleting surface lines also deletes entity lines?
    2004-07
    3
    Unhappy Deleting surface lines also deletes entity lines?
    I am working on a roadway project and have created a surface for it. I've created a surface from a point group. After creation of the surface, I import the 3D lines to begin editing them so I can contour the roadway properly. The problem arises when I try to delete surface lines that I don't need. If I select the delete surface line command, and individually pick the lines, everything works fine. If I try to window a group of surface lines, then the entity lines (edge of pavement, centerlines, sidewalk lines, etc.) are also deleted... but not all of them. Some of them are left behind (perhaps 80% of the entity lines included in the window are erased).
    Has anyone else had this problem? None of the other designers in my office have ever seen this, and it only happens in this one project. Any ideas on how to fix it?
    2003-10
    688
    Default Re: Deleting surface lines also deletes entity lines?
    Just to be clear, you are using the surface "definition" and "edit... delete line" from the prospector right?
    2006-12
    Loveland, CO
    734
    This was reposted in the LDT discussion so I'm assuming the OP was using LDT and just posted in the wrong discussion group.
    Brian J. Hailey PE
    CAD-1
    Civil3D PLUS My blog
    At Your Desk Training
  1. Replies: 3
    Last Post: 2011-02-09, 03:29 PM
  2. C3D crash when deleting TIN lines.
    By wesley.184793 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2008-05-31, 12:30 AM
  3. Deleting surface lines deletes entity lines also?
    By jmmacdougall2 in forum Land Desktop - General
    Last Post: 2008-02-07, 03:08 PM
  4. deleting surface lines
    By mcretu in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2006-10-01, 10:27 PM
  5. I need help with deleting double lines
    By ron.vail in forum AutoCAD General
    Last Post: 2004-07-21, 08:06 PM
