Thread: templates
    2008-02
    3
    Default templates
    I can only see 2 color templates for 24" printer in english architectual.. Isn`t the 24" printer among the most used or am I missing something?? AutoCad 2005
    Mike
    2008-02
    3
    Default Re: templates
    Do u people make ur own templates??
    2005-07
    2,356
    Hi Mike welcome to AUGI.
    Generally you will find that most people will create their own templates, although would use one of the templates that come with Autocad as a base rather than starting from scratch.
    Is there a particular problem/issue that you're running into?
    2005-06
    in the upper right corner
    3,508
    Quote Originally Posted by kayml View Post
    Start with a "clean" drawing that has everything you want in it (layers, text styles, etc, and do a "save as" to a .dwt file, place it in a directory of your choice. You can go to "options" and have that directory be the default template folder when you type "new" and/or "qnew".
    We have several templates, specifically for plans, elevations, details, and specific layout sheet sizes etc.
    2008-02
    3
    Thanks,, just a little common sense .....
  1. Replies: 0
    Last Post: 2014-11-30, 01:16 PM
  2. 2014: Setting Up Project Templates & View Templates???
    By sbrennan in forum Revit MEP - General
    Last Post: 2013-08-29, 09:17 PM
  3. Replies: 0
    Last Post: 2011-12-09, 02:57 PM
  4. View Filters and view Templates... But not View Templates
    By saeborne in forum Revit Architecture - General
    Last Post: 2010-09-13, 04:40 PM
  5. Revit architecture view templates or Revit Structure view templates
    By rob.127056 in forum Revit Architecture - General
    Last Post: 2009-02-13, 07:56 PM
