Results 1 to 9 of 9
Thread: Renaming Tags
    2008-02
    Default Renaming Tags
    Is it possible to rename Tags in Blocks using AutoLisp?
    2007-08
    202
    Default Re: Renaming Tags
    Hi,
    You can get ideas from this little routine
    (defun rename-tag (blockname oldtag newtag / def ent loop elst)
      (if (setq def (tblsearch "BLOCK" blockname))
        (progn
          (setq ent	 (cdr (assoc -2 def))
    	    loop T
          (while (and ent loop)
    	(setq elst (entget ent))
    	(if (and (= (cdr (assoc 0 elst)) "ATTDEF")
    		 (= (cdr (assoc 2 elst)) (strcase oldtag))
    	  (progn
    	    (entmod (subst (cons 2 newtag) (assoc 2 elst) elst))
    	    (setq loop nil)
    	(setq ent (entnext ent))
          (command "_attsync" "_n" blockname)
      (princ)
    If you don't want to use command, replace:
    by
    (if (setq ss (ssget "_X" (list '(0 . "INSERT") (cons 2 blockname))))
    	(repeat	(setq n (sslength ss))
    	  (setq	ent  (ssname ss (setq n (1- n)))
    		att  (entnext ent)
    	  (while att
    	    (setq elst (entget att))
    	    (= (cdr (assoc 0 elst)) "ATTRIB")
    	    (if (and	(= (cdr (assoc 0 elst)) "ATTRIB")
    	      (entmod
    		(subst (cons 2 (strcase newtag)) (assoc 2 elst) elst)
    	    (setq att (entnext att))
    2007-08
    202
    Another way using Visual LISP functions
    (defun rename-tag (blockname oldtag newtag)
      (vl-load-com)
      (or *acad*
          (setq *acad* (vla-get-ActiveDocument (vlax-get-acad-object)))
      (if (tblsearch "BLOCK" blockname)
        (progn
          (vlax-for	obj (vla-item
    		      (vla-get-Blocks
    			*acad*
    		      blockname
    	(if (and (= (vla-get-ObjectName obj) "AcDbAttributeDefinition")
    		 (= (strcase oldtag) (vla-get-Tagstring obj))
    	  (vla-put-TagString obj (strcase newtag))
          (if (ssget "_X" (list '(0 . "INSERT") (cons 2 blockname)))
    	(vlax-for ref (vla-get-ActiveSelectionSet
    			*acad*
    	  (foreach att (vlax-invoke ref 'getAttributes)
    	    (if	(= (strcase oldtag) (vla-get-Tagstring att))
    	      (vla-put-TagString att (strcase newtag))
      (princ)
    2005-08
    1,043
    gile,
    Instead of using ssget to find all the inserted blocks, you can grab that information from the dxf information of the block definition. Just an FYI..
    (defun ReturnInsertedEnames (BlkName / EnameList)
        (foreach lst (entget (cdr (assoc 330 (entget (tblobjname "block" BlkName)))))
            (if (equal (car lst) 331)
                (setq EnameList (cons (cdr lst) EnameList))
        EnameList
    (defun c:Test ()
        (ReturnInsertedEnames (cdr (assoc 2 (entget (car (entsel "\n Select block: "))))))
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Tim, that's perfect
    Thanks
    Here is my 2¢ (just an extension of your function)
    to select blocks on particular sheet
    (defun ReturnInsertedEnamesOnLayout (BlkName LayoutName / EnameList)
    	      (if (eq LayoutName (cdr (assoc 410 (entget (cdr lst)))))
            EnameList
    Usage :
    (ReturnInsertedEnamesOnLayout (cdr (assoc 2 (entget (car (entsel "\n Select block: "))))) "Layout1")
    ~'J'~
    2007-08
    202
    Very nice Tim !!!
    I didn't know this, and I thank you very much to share this trick.
    2005-08
    1,043
    You're welcome, both. I just share what little I know, and hope it is useful to others.
    2007-08
    202
    Tim,
    I notice that if some bloc have been erased from the drawing, their enames still appear in the list.
    Just for fun, another way to write the routine
    (defun ReturnInsertedEnames (BlkName)
      (mapcar 'cdr
    	  (vl-remove-if-not
    	    '(lambda (x) (= (car x) 331))
    	    (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" BlkName))))
    2005-08
    1,043
    Quote Originally Posted by 'gile' View Post
    Good catch. I would have to think that has something to do with being able to undo everything. Maybe there should be a check to make sure you only get non-erased entity names.
        (vl-remove-if
            'vlax-erased-p
            (mapcar 'cdr
                (vl-remove-if-not
                    (entget (cdr (assoc 330 (entget (tblobjname "BLOCK" BlkName)))))
  1. Renaming Attribute Tags?
    By rkingery in forum AutoLISP
    Last Post: 2013-01-09, 01:19 PM
  2. renaming blocks
    By d_m_hopper in forum AutoLISP
    Last Post: 2010-06-21, 04:24 AM
  3. Layer Renaming
    By CadDog in forum AutoCAD General
    Last Post: 2009-03-09, 03:47 PM
  4. Renaming worksets
    By sblackburn in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2008-07-29, 01:17 PM
  5. Renaming Fields in Room Name Tags
    By caroline1772 in forum Revit Architecture - General
    Last Post: 2003-09-04, 01:23 AM
