Thread: data linking a pipe network
    2015-12
    Lansing, MI
    10
    Default data linking a pipe network
    I've created a base drawing that include my entire pipe network but want to create seperate drawings for the profile views. In order to do this I've data linked my pipe network but when it comes into the drawing it loses the label/pipe/structure styles of the original drawing. For example I have a style for existing catchbasins with a city standard block attached for plan view but when I create the reference for the data link it reverts to the city standard manhole block for all structures in the drawing. The same thing happens for the pipe styles which is a bigger pain because there are a larger number of styles. Anyone know if there is a way to have the data link keep it's original properties? Thanks.
    2008-02
    14
    Default Re: data linking a pipe network
    when you creating a quick link from source file, there will be a options window,
    add a tick near the Add Source Labels and then create a link.
    (i am using a russian version so my translate could not be exact, like my posts )
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,446
    Hi Shane,
    Make sure the styles you want to use are in your DWT that you are using for your Planset. You may still need to create the reference and reset the styles in each sheet, but even doing this is much faster than everything you used to do when creating numerous plansheets. (Even with Xrefs)
  1. UT330-1: AutoCAD® Civil 3D® GIS: Migrating Pipe Network Data for Infrastructure Projects
    By Autodesk University in forum Utilities and Telecommunications
    Last Post: 2015-08-07, 05:38 PM
  2. 2012: Pipe Network Data Reference not keeping Styles
    By chris.safford in forum AutoCAD Civil 3D - Pipes
    Last Post: 2014-11-18, 04:37 PM
  3. 2014: Pipe Network Data Reference assigning incorrect Reference Alignment Name
    By dpresley58437170 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2014-09-03, 11:33 AM
  4. Data Reference a Portion of a Pipe Network or Pressure Network
    Last Post: 2013-12-19, 04:09 PM
  5. Data Shortcut Pipe Network & Design Pipe Network
    By Openwheeler in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-09-18, 03:47 PM
