Hello out there,
In one drawing only, I cannot Wblock, copy or paste and if I try to save the file as a DXF, when I try to open the DXF file, I get a blank screen. Does anyone know anything about this. I am using AutoCad2002.
Thanks.
Hello out there,
Thanks.
Hi, I had a problem like this after I had transfered from AutoCAD 2000i to 2007 LT. Initially, after I had saved the drawings backwards to 2000 from 2007LT my cut, paste & wblock were unusable. After adding a patch to my 2007 the problem was solved but I was left with hundreds of drawings that were extremely annoying. Is it possible that the drawing you are working on has come from someone else with a similar problem on their system? One solution was to save the drawings backwards to R14 then open again and resave. I did this with AutoCADs free download DWG Trueview/DWG Convert so that I could batch convert my drawings. Perhaps you could try it? Hope it helps
Thanks, I tried that and the very explicit purge command, thank you. I don't see the Regapps option when I type the (hyphen) Purge command.
Hi Brenda, no, it's actually a drawing I started myself but I did import blocks etc. from other drawings from others.
Thanks
I just sent the same file to a friend who was able to WBlock, copy and paste. He sent it back to me but I still can't do any of those things. Very strange.
My problem was fixed by downloading DWG TrueView from Autodesk. Thanks for the help.
