Results 1 to 9 of 9
Thread: Double door
    2005-05
    71
    Default Double door
    Anybody know how to swing the panels of a double door independantly?
    TAB Associates, Inc.
    The Architectural Balance
    Bill Nutkins, Project Manager
    billynutts@yahoo.com
    www.tabassociates.com
    2003-09
    Missouri
    50
    Default Re: Double door
    Quote Originally Posted by billynutts View Post
    I have not tried this but an idea that comes to mind would be to create a framed opening and then place two frameless doors and place the swings how you would like them. That way when you adjust the display rep to open the doors they should swing opposit. To get every thing to move together you could group them or create an anchor on the wall. This is an interesting question I might give this a try.
    2005-05
    71
    Cambell thanks for the reply. ACA has a built-in double door which has opposite swings just not one which can show two different swings on the same side. The reason we doo this is to show the dominant side or a fixed side of a double door. Thanks.
    2006-12
    Big "D"
    3,711
    Quote Originally Posted by campbell.58097 View Post
    Yeah, that's the way to do it. Use a door/window assembly and 2 frameless doors. Then you can anchor them to the assembly. When you insert it, it will anchor to the wall just like a normal door / window would.
    Why is it called common sense when it is so rare?
    RevitForum.org
    2002-09
    Madison, WI
    4,447
    Are you looking more for like double doors that swing in different directions (I'm thinking like waiter/resturant/buter doors). Or do you just want one to be shown open 90 degrees and one to show open 45 or something like that. I thought that ACA came with a "butler" style door, but I guess I can't seem to find it. Maybe I saw that on the Adesk website. Hmmm.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2005-05
    71
    I'll try the dorr/window assembly route. Dave they do have a butler type of door its in the Design Imperial catelog. Thanks guys.
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,862
    Quote Originally Posted by david_peterson View Post
    Create a style that has a door type (Design Rules tab) of Single-Dhung or Double-Dhung for a double-acting door. [Use Communicating type when you have a single door frame with two door leaves, swinging in opposite directions and hinged on the same side. Frequently used in hotels/motels to allow two rooms rented by the same group of people to be open to each other without going into the main corridor.]
    David Koch
    2005-05
    71
    More like french patio doors where one is fixed and one is not or one is the dominant panel.
    2003-03
    1,862
    You will either need to add custom blocks to a Double type Door, which may give strange results when used for a door of a different width than that for which the block was drawn, or to set up a Door/Window Assembly, with a zero-width mullion between two cells for two Single type Doors. That may present scheduling challenges, unless you only use the D/WA and its included doors for graphic purposes and pop in a non-plotting double door in the same spot for scheduling purposes.
    David Koch
  1. Dynamic Double Door Set, scale the two door leafs uniformly
    By b.boyes in forum Dynamic Blocks - Technical
    Last Post: 2012-08-08, 03:58 PM
  2. Double Egress Door ?????
    By Kal_digital in forum AutoCAD General
    Last Post: 2008-11-18, 04:58 PM
  3. Replies: 1
    Last Post: 2008-09-17, 04:23 PM
  4. Double wall with door through both
    By CADMama in forum Revit Architecture - General
    Last Post: 2007-11-03, 12:19 AM
  5. Need single-door equivalent of Revit's "Store Front Double Door"
    By Ralph.143107 in forum Revit Architecture - Families
    Last Post: 2007-10-27, 11:49 PM
