Results 1 to 6 of 6
Thread: Layer Properties status line
    2006-01
    Hiding
    67
    Default Layer Properties status line
    I seem to have a small problem with the layer properties manager. Normally it has a status line to say how many layers in the drawing etc. On this computer there is no status line. Is there a variable that switches this information off? The other computer that runs 2006 has the status line, but not this one.
    I have restarted the computer, but still no status line
    Can anyone offer any advice?
    Many thanks in advance
    T
    Earth
    9,805
    Default Re: Layer Properties status line
    It looks like the current layer is missing also (in the upper right)?
    The only thing I can think of would be to try and run a repair on your .NET framework install.
    R.K. McSwain | CAD Panacea |
    2006-01
    Hiding
    67
    Thanks for your reply. I didnt even notice that part was missing!
    Is that solution something the "admins" have to do, or how would I do that?
    Thanks again
    T
    Earth
    9,805
    If you have permissions.. follow this.
    Add/Remove Programs
    Microsoft .NET framework x.0
    Change/Remove
    Repair
    Next
    2006-01
    Hiding
    67
    Add/Remove Programs
    Change/Remove
    Repair
    Next
    Unfortunately I can only get to the change/remove then it asks me to contact the admin Looks like I'll have to contact them and wait (and wait)
    Thanks for your help. Much appreciated.
    T
    2006-01
    Hiding
    67
    The update was the key.
    Thanks again
    T
  1. changing layer properties with lisp (line type)
    By maomuchmar in forum AutoLISP
    Last Post: 2014-06-23, 06:23 AM
  2. Override Layer Properties by Viewport Via Command Line
    Last Post: 2008-10-12, 04:25 PM
  3. Add Optional Status to any layer
    By trythefly in forum AutoLISP
    Last Post: 2007-03-08, 05:54 PM
  4. Status icon in layer dropdown
    Last Post: 2006-06-09, 01:03 AM
  5. Layer Properties Dialog Box, Status Line Missing
    By ipengilly in forum AutoCAD General
    Last Post: 2005-04-27, 11:43 AM
