Results 1 to 10 of 11
Thread: printing CTB table
    2005-03
    Utah
    31
    Default printing CTB table
    Is it possible to print out an AutoCAD CTB table, such as in Microsoft Excel? If yes, how is it done. I have tried simply changing the exension of the file, which did not work (although I was pretty sure this wouldn't work even before I tried). Does anyone know how to do this?
    Any help would be appreciated, even if it is a definitive answer "no", it can't be done.
    Thanks.
    150700
    3,421
    Default Re: printing CTB table
    Quote Originally Posted by CAD cowboy View Post
    Thanks.
    Yep. There is a tool on the Autodesk site that allows this.
    LINK
    AUGI Addict tedg's Avatar
    2005-06
    in the upper right corner
    2,318
    Thanks.
    Somewhere in here (AUGI threads) I found a link to download a "plotstyleviewer.exe".
    It's a free program you can print out plot styles.
    I did a search but couldn't find it
    If I can find where I got it I'll post agian
    Ted
    ____________________________________________________________________________________
    AutoCAD 2012 - REVIT Structure 2012 - MicroStation V8i - Windows 7 Professional - (dabble with Inventor 2012)
    Houston
    7,542
    Thanks.
    Depending on what version you have, take a look:
    http://cadpanacea.com/node/38
    2005-03
    Utah
    31
    Sorry that I did not get a reply to everyone yesterday.
    Thank you all for the various suugestions that you gave, I appreciate it and was able to find a solution to my problem using your tips.
    2008-01
    74
    Thanks.
    The best thing I have found is a prog called Layer Lexicon. What I do is create a DWS drawing with all of our standard layers drawn as a line. Using Layer Lexicon I can then create an html file of these layers, in color. I convert that to a pdf using acrobat, and i then have a printable color chart of the ctb file. I also use the dws file to do laytrans and cad standards checks.
    http://www.caddee.com/llexicon.html
    I could stop if I wanted to Dr._House's Avatar
    2007-07
    Milwaukee, WI
    217
    What about for AutoCAD MEP 2010? I have downloaded a couple of the older versions but it's not looking for the right DLL file. Is there a 2010 version out there?
    CAD Manager
    Ring & DuChateau
    Milwaukee, WI
    2007-07
    Milwaukee, WI
    217
    Found a cool site that you can use and then paste to excel from! Works really nice!
    http://www.xcad.ch/tests/ctbviewer.php
    CAD Manager
    Ring & DuChateau
    Milwaukee, WI
    2006-07
    Thanks Dr_House for that great find. Creating myself a master spreadsheet now with all our company's ctb files.
    Bryan Collins (Cadd Technician)
    2008-02
    6
    Quote Originally Posted by Dr._House View Post
    This works awesome but will not paste the lineweights into Excel. The only saving grace is that it does show you what the lineweight will be with the output text.
  1. Replies: 1
    Last Post: 2006-12-12, 06:36 AM
  2. Replies: 1
    Last Post: 2006-10-13, 04:58 PM
  3. Linking AutoCAD Object Data Table to Access table
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-05-02, 02:54 PM
  4. Printing Hp Laserjet 5000- Customer Logo not printing solid
    By thomas.huckabee in forum AutoCAD Plotting
    Last Post: 2005-05-26, 08:42 PM
