Thread: Render Background Ccolor AutoCAD 2008
    2006-03
    2
    Default Render Background Ccolor AutoCAD 2008
    I'm having issues with the render background color in 2008. It used to be all you had to do was change the actual background color in model space and your rendered image background matched.
    I've tried everything I can think of however, the background always comes out black. I need white.
    Any help is greatly appreciated.
    2003-12
    Pittsburgh, PA
    355
    Default Re: Render Background Ccolor AutoCAD 2008
    Could it be the background colors of one of the 3D displays under Options > Display > Colors ?
    2006-03
    2
    Quote Originally Posted by lpseifert View Post
    I got it. You have to create a new view, set the background to solid, set the background color to 255, 255, 255.
  1. Texturas e Render Autocad 2008 x 3D Max
    By panzaguerson in forum Português - Computação Gráfica
    Last Post: 2008-10-06, 06:35 PM
  2. Render Autocad 2008
    By rm_danutzzz in forum AutoCAD General
    Last Post: 2008-02-20, 05:26 PM
  3. AutoCAD 2008 get Polyline to render flat instead of curved in the corner
    By vavalexus in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-06-07, 10:18 AM
  4. Using AutoCAD 2008 to render - good idea or bad?
    By gbelous in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-05-18, 12:44 PM
  5. AutoCAD 2008 render of new project in NYC
    By MDzyne in forum AutoCAD Gallery
    Last Post: 2007-04-12, 03:23 PM
