Hi ALL,
I have 2005 Mechanical.
The AutoCAD 2005 help files worked fine without any problem until I came back from holiday.
(I have no problem with opening Mechanical Help files.)
In AutoCAD 2005 Help contents tab, under "AutoLISP,Visual LISP,and DXF" & "ActiveX Automation and VBA",
I now can not open all following sub-help files:
"AutoLISP Reference",
"AutoLISP Developer's Guide",
"AutoLISP Tutorial"
and "DXF Reference";
"ActiveX and VBA Developer's Guide",
"ActiveX and VBA Reference",
"Sheet Set Objects Reference"
and "Connectivity Automation Reference".
All error messages state "an error has occured in the script on this page. ... object doesn't support this property or method."
I have checked that help support path is correct under Files tab in Option:
Menu, Help, and Miscellaneous File Names
- Help File
- C:\Program Files\Autodesk\Acadm 2005\Help\acad161.chm
Also, I can not load LISPs which were working fine. The error message says "ERROR: bad argument type: stringp nil; error: An error has occurred inside the *error* functionAutoCAD variable setting rejected: "OSMODE" nil".
I have now reinstalled AutoCAD 2005 Mech. I can load my LISPs but the re-installation doesn't solve the HELP files opeing problem.
Any help would be appreciated.
Cheers.
Ke
