Thread: C-purlin
    2007-09
    174
    Default C-purlin
    Hi,
    I have created a C-purlin family (Australian) but some of the restrictions must be wrong as it doesn't behave properly.
    I have been going through it and can't figure out where the problem is.
    Would appreciate if someone could have a second look
    Thanks
    Jonas
    2015-11
    Wellington, New Zealand
    103
    Default Re: C-purlin
    Hi,
    Revised rfa file attached, just a couple of small mistakes and easily missed the first time.
    1) Your profiles need to have there origin defined; (the default profile template has the horizontal reference plane origin tick box turned off).
    2) You need to constrain your profiles so they maintained a constant insert point, open the profile in the attached rfa to see what I have done.
    (I haven’t tested this in a project so it may still have a few bugs)
    Cheers
    2007-09
    174
    THANKS
    I had a look at the what you did - adding the EQ dimensions to lock it in to position.
    I wouldn't have picked up that the ref planes had the origin turned off. It make sense though.
    Thanks again
    Jonas
  1. 2012: Purlin as well
    By chrisr in forum Revit Architecture - General
    Last Post: 2012-01-06, 04:57 PM
  2. Purlin releases and deformations
    By mark.martin.se in forum Robot Structural Analysis
    Last Post: 2011-01-13, 09:17 PM
  3. ASD Purlin Cleats
    By gmichalczyk in forum AutoCAD Structural Detailing
    Last Post: 2009-10-16, 03:55 AM
  4. purlin question
    By cheryla in forum Revit Architecture - General
    Last Post: 2008-05-13, 08:37 PM
  5. need purlin help!!!
    By Jheadley13 in forum Revit Structure - General
    Last Post: 2007-10-09, 08:06 PM
