Thread: "Reference Other View" with section head
    2007-08
    Default "Reference Other View" with section head
    I have a standard section detail that is repeated in a number of locations. Is it possible to drop in a Section head and tail that would reference back to that standard detail? It would act similar to the View-Callout command and checking the "Reference other view" box and selcting the appropriate detail.
    If there is no direct solution, does anyone have a workaround to accomplish this same technique?
    I could stop if I wanted to Teresa.Martin's Avatar
    2004-11
    438
    Default Re: "Reference Other View" with section head
    Hi. You have this option when you first create the section. You should see an option on the options bar to reference the other view (detail, another section, etc.).
    I hope this helps.
    Best regards,
    2004-06
    Memphis TN area
    7,048
    Sections, callouts, and even elevations all have the "Reference Other View" command available, where you can reference a different section, callout, or elevation, or even a drafting view that might be a typical scenario repeated many times.
  1. Improve the way "reference other view" view selection works
    By houston.cad in forum Revit Platform - Wish List
    Last Post: 2014-12-19, 06:22 PM
  2. I wish Revit could "Reference Other View" from linked files
    By sfong in forum Revit Architecture - Wish List
    Last Post: 2011-10-17, 03:14 PM
  3. Create a "static" section (detail view) from a "live" section
    By matt__w in forum Revit MEP - General
    Last Post: 2009-09-22, 04:18 AM
  4. "Reference other view" note/tag
    Last Post: 2009-01-31, 04:00 PM
  5. Looking for file "AUS Section Head - 1 point Open"
    By kimheaver in forum Revit Architecture - Families
    Last Post: 2004-09-05, 02:48 AM
