Thread: Match Properties for MEP Styles
    2008-01
    67
    Default Match Properties for MEP Styles
    Hello,
    Is there a way? In traditional CAD, I survive on the matchprop command.
    As an example, I draw a few plumbing systems on different systems, and if I want to change one to the other, I change 'System Name' from the 'System' section of the 'Properties' palette. Shouldn't there be a way to do this with a command? Maybe I can write a macro or a small lisp routine to read a source system name from an object and write to another (if this feature is not available)?
    Paul
    2008-01
    67
    Default Re: Match Properties for MEP Styles
    Cmon,
    If this feature is not available OOTB, then there has to be a way to programmatically extract and set the system name of an object. Maybe this is through the .NET api or maybe through LISP? I know someone has to know.
    Paul
    2006-12
    29
    When you draw multiple plumbing lines (or anything for that matter) you can right click on the object you want to modify (change the system type) and select "Plumbing Line Modify"
    This will pop up a dialog box that you can change the system to any system in the drawing.
    This will be different depending on the object you select, but you can do this for basically anything.
    2008-01
    67
    Smile Re: Match Properties for MEP Styles
    Thanks ndbrainard for the help. This is nice; however, I would still like to have a very fast shortcut for matching one system to another, similar to matchprop for regular ACAD objects.
    2003-10
    San Francisco CA
    1,190
    Quote Originally Posted by paulelowndes View Post
    Hello,
    Paul
    As far as I know this is currently not possible. Sounds like a great Wish List item to me.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
  1. Match Properties
    By towers in forum AutoCAD Civil 3D - Land Desktop Companion - General
    Last Post: 2009-08-27, 01:52 PM
  2. Match Properties
    By Zia Farooqi in forum AMEP Wish List
    Last Post: 2009-07-05, 12:38 AM
  3. Match Properties for Styles
    By Civil 3D Wishes in forum Civil 3D Wish List
    Last Post: 2007-10-01, 05:04 PM
  4. Match Properties Styles
    By jrives in forum ACA Wish List
    Last Post: 2006-12-07, 04:00 PM
  5. Match Properties to Styles
    By BCrouse in forum ACA Wish List
    Last Post: 2006-06-22, 03:54 AM
