Thread: Copy Sheet
    I could stop if I wanted to Batman's Avatar
    2004-12
    324
    Default Copy Sheet
    How does one copy and / or duplicate sheets?
    How would I go about creating multiple new sheets without having to 'Create New Sheet' 50 clicks?
    Is it possible to make 10 new sheets in one hit?
    2003-04
    Irvine, CA
    6,770
    Default Re: Copy Sheet
    No built in command to do it. You can do this however which can be pretty quick:
    Select a sheet (in Project Browser) that has no views on it > CTRL + C (copy to clipboard)
    Click in Drawing (View) Window
    CTRL + V (Paste from Clipboard)
    www.revittv.com claims to provide such a feature.
    2005-07
    3,220
    You could also go through the pain of creating your 50+ sheets manually in an empty project and then use the Insert From File command in any project where you need a bunch of sheets, select how many/whichever you want (you can name & number them if you want too) and insert them into your project. So once you do this, you'll just insert into projects rather than create from scratch.
  1. Copy stuff from sheet to sheet
    By captjim in forum Revit Structure - General
    Last Post: 2008-09-02, 09:13 PM
  2. Copy enitre sheet set
    By DNC.Gijsbers in forum ACA General
    Last Post: 2007-08-09, 05:03 PM
