Thread: x,y coords and fields
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,233
    Default x,y coords and fields
    Howdy y'all.
    I've been trying to find a way to display the x,y coordinates in a drawing (see here). Ordinate dims are cumbersome. It's been suggested that I create a block with fields in the attributes for the coords. I don't see a field for this. Does anyone have suggestions? TIA
    AutoCAD Civil3D 2013
    Gig 'Em, Aggies!
    Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Default Re: x,y coords and fields
    Quote Originally Posted by Maverick91 View Post
    Howdy y'all.
    like this?
    (all i did was look at the bottom of the web page for this link)
    S&D DB Sharing Forum
    1,233
    Quote Originally Posted by Chris.N View Post
    like this?
    Yup! That helps!
    Gig 'Em, Aggies!
    2006-09
    7
    First insert the block, the x,y,z, will be determined by the insertion point.
    type field, go to Objects, select the block, go to position, then you will have the options for
    the x,y,z the the units as your wish
  1. 2011: Paste Original Coords
    By bellis.239472 in forum AutoCAD General
    Last Post: 2011-06-14, 06:02 PM
  2. No UVW coords when exporting
    By dpasa in forum Revit - Rendering
    Last Post: 2010-02-18, 05:31 AM
  3. Using fields in a block to display x,y coords
    By ajzoch in forum AutoCAD Fields
    Last Post: 2010-01-28, 09:05 AM
  4. How to get quadrant coords from subentity. .
    By M. Kubitza in forum AutoLISP
    Last Post: 2009-05-29, 01:30 PM
  5. shared coords
    By hanff in forum Revit - API
    Last Post: 2008-09-20, 08:05 PM
