Hi, what is the best way to do single plumbing plan but with 3D lines so you could view as isometric?
I was trying to work it out but no luck especially when it comes to plan view line visibility.
Thanks
Thanks
That would be very tedious. Unfortunately you can't input coordinates as you draw lines like Autocad. You can't ad a z value in plan. It is possible but you would need to create multiple workplanes which could be very time consuming.
Revit MEP would be a better tool. If you dontwant to buy it, i dont see that has a big deal using model lines. Just time consuming. I'm assuming you don't want to get any information out of those right?
