Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: '2D polyline' & 'polyline' What's the difference?
  1. #11
    2007-06
    97
    Default Re: '2D polyline' & 'polyline' What's the difference?
    Quote Originally Posted by Dave F. View Post
    Have you got it set to 2? Did it convert when you opened the example I posted?
    Where is that example?
  2. #12
    2006-09
    255
    Quote Originally Posted by seant61 View Post
    Err.... Should have been attached to message 4.
    Here it is.
  3. #13
    2007-06
    97
    No automatic conversion here (2004). I guess it requires an explicit “Convert” (or “ConvertPoly” if LWPoly => 2DPoly required). PLINETYPE must only apply to polys created within the current drawing session.
    I can’t make any suggestions other than the previously stated FIT/SPLINE issue. One thing I did notice with those PEDIT options; if the poly is straightened via PEDIT-DECURVE, it reverts to a LWPoly. If the curve is straightened via the Properties Window FIT/SMOOTH – NONE, it remains a 2DPOLY. Probably not germane to the OP, but interesting none the less.
  4. #14
    2003-10
    706
    Quote Originally Posted by jaberwok View Post
    FWIW, PEdit/Fit and PEdit/Spline turn a LWpolyline into a 2D Polyline (not a Spline) by curve-fitting.
    It's still considered a "splined" polyline though... until you break, trim, or explode it.
  5. #15
    0,0,0 The Origin
    8,570
    Quote Originally Posted by Coolmo View Post
    True but not my point.
    lwpolyline becomes 2dpolyline
  6. #16
    2006-12
    2
    Hi
    I've got a combination of two types of entity - '2D polyline' & 'polyline'.in a dwg.
    For some reason they display different context menus when I select them & right-click.
    They were created the same way I think, individual lines joined using pedit.
    I've got the PLINETYPE system variable set to 2 so they're all optimized to 2d.
    When I use the CONVERT command it converts the '2d Polylines' into 'polylines'. Which is what I want.
    However, I still don't understand how I created the '2D polylines' & why , having PLINETYPE set to 2 it didn't convert when I reopened the dwg.
    I still don't understand what the difference between the two is. They have no Z values & are in the world UCS plain, just at different elevation, which, as I understand it, doesn't make any difference.
    Any ideas?
    Thanks for your help.
    I have found that AutoCAD drawings that are exported from other products i.e. Inventor, create a lot of 2d Polylines. Converting 2d polys to polylines reduces file size dramatically.
    Could this be the reason? After I run the convert command, I run "Overkill" which picks up (some of) the duplicates.
    Roy
  7. #17
    2008-09
    4
    Red face Re: '2D polyline' & 'polyline' What's the difference?
    I have been having a similar problem, but this may be a separate thread. I am working in LT 2008 and the program spontaneously started making polylines with just one handle. Sometimes. I can draw several plines with no problem, then the next one has just one handle. I am picking the button on the tool panel, not doing anything different. Rectangles have one handle too.
    I did't understand the discussion about pline vs wlpline although I did check that 'plinetype' is set to 2.
    I should note that I am working on a Mac using Fusionware to toggle to windows so I can run AutoDAD. I'll try a reboot, that sometimes helps work out the Mac/PC culture clash.
  1. 2013: z value at intersection points in 3d polyline and polyline
    By jaychandran in forum AutoCAD Civil 3D - General
    Last Post: 2013-10-30, 05:20 PM
  2. Difference Between 2D Polyline and 3D Mesh
    By brandenroth1 in forum AutoCAD General
    Last Post: 2011-10-10, 07:39 PM
  3. Difference between Polyline & 2D Polyline ?
    By sandeep_koodal in forum AutoCAD General
    Last Post: 2009-01-09, 12:39 PM
  4. Replies: 14
    Last Post: 2007-09-10, 05:01 PM
