Results 1 to 9 of 9
Thread: HELP! CAD GONE CRAZY
    2007-04
    Winnington
    91
    Exclamation HELP! CAD GONE CRAZY
    I don't know if I'm putting this in the right place, but I need help please. I gave my coworker the command mvsetup to rotate his viewport, he used it, now his mouse is not working right, he's lost his ability to edit with a double click and he's blaming it on the mvsetup. Anyone who has any insight on how to fix this please please help!
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: HELP! CAD GONE CRAZY
    Quote Originally Posted by sday.137422 View Post
    I don't think mvsetup changes it, but make sure PICKFIRST is set to 1, and DBLCLKEDIT is set to ON.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    A little more information on your (his) setup would be helpful. Which version is being used?
    Until then, MVSETUP should not have effected the editting by double click.
    If you are using a newer version, (2007 or 2008), I believe you need to check the double click settings in the CUI.
    2007-04
    Winnington
    91
    Thanks so much guys! Really appreciate it, he's got it all fixed. Any suggestion as to how that would change seemingly on it's own?
    2007-04
    Winnington
    91
    We're also 2006, no special customization going on.
    2002-01
    jUSt Here (a lot)
    9,106
    Not really. Some errant AutoLISP programming possibly.
    2007-04
    Winnington
    91
    This is so bad. He's so against trying new things and now he thinks that running that new command (which I've been running for years) did it. He's never going to listen to me again!
    2002-01
    jUSt Here (a lot)
    9,106
    Then don't tell him about the DVIEW command with the TWIST option or the UCS command with the OBject option followed by the PLAN command.
    2006-05
    New Jersey
    147
    Chances are he was pushing a few buttons in Options...
    I get this all the time: "I dont know what happened...I didnt change anything..."
    Then later I come to find out they did...
  1. 2015: Using CW as windows - Crazy?
    By crullier in forum Revit Architecture - General
    Last Post: 2015-08-11, 11:02 PM
  2. 2 Dwg No's (am I crazy?)
    By dandlf in forum AutoCAD Sheet Set Manager
    Last Post: 2009-02-27, 04:33 PM
  3. Crazy Connectors!
    By Tyveka in forum Revit MEP - General
    Last Post: 2007-10-04, 05:21 PM
