Thread: Unable to change Feature line, Line style
    2007-08
    Brisbane, Australia
    42
    Unhappy Unable to change Feature line, Line style
    I have been unable to change a feature line, line style. For my car park, I have a face of kerb feature line that will only display as continuous. I have changed the feature line style, the layer style and tried to change it in drawings that xref the model. Nothing has worked.
    Any ideas?
    2007-08
    Brisbane, Australia
    42
    Arrow Re: Unable to change Feature line, Line style
    So the answer is that feature lines, like 3d polys, will not display a line style when ploted. Knowing the answer to my problem still doesn't solve it. Does anyone know how to show line styles of dynamic objects? Is the only answer using corridors?
    2007-04
    57
    Default Re: Unable to change Feature line, Line style
    What I am experiencing is similar to if you do not have linetype generation enabled on a polyline. The linetype, dashed 2 in my case, shows and prints just fine as long as it's a long segment, but where I have a fairly detailed feature line it displays solid. I haven't been able to recreate this instance but I believe that if the feature line style has the 3d display turned on it will not display any linetype at any point. Maybe there is a work around for this. If I find out anything I will let you know.
    Good Luck,
    D Manning
  1. saving feature line style...
    By tpluie318707 in forum AutoCAD Map 3D - General
    Last Post: 2012-08-03, 10:49 PM
  2. Unable to change slab edge to solid line
    By Dupont in forum Revit Architecture - General
    Last Post: 2009-12-16, 07:17 PM
  3. feature line/surface style
    By oneill.tracy in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-04-09, 07:52 PM
  4. Default Feature Line Style
    By Civil Samurai in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-19, 12:45 PM
  5. Replies: 8
    Last Post: 2006-02-07, 03:35 PM
