Thread: Elevation in 3D ---> 2D
    2006-02
    29
    0 Did you find this post helpful? Yes
    Default Elevation in 3D ---> 2D
    Hi!
    We have a project where we have recieved a dwg file that is 3D.
    There are a lot of corners and stuff on the building, and it`s a bit difficult to get the elevations as we want them with the view directions that AutoCad has.
    Is there a way to get these elevation views to 2D?
    We normally use Revit in our projects, but drawing the hole building in Revit just to get this to work will be at bit too time consuming...
    Best Regards
    Henning
    0,0,0 The Origin
    8,568
    Default Re: Elevation in 3D ---> 2D
    Quote Originally Posted by roland.106412 View Post
    Hi!
    Best Regards
    Henning
    AutoCAD has no restrictions on possible view direction.
    To view exactly on a face, it may be easiest to create a UCS on the face and then issue the Plan command.
    John B
  1. 2016: REVIT 2016: Spot elevation/Invert elevation for fabrication part.
    By swapr78 in forum Revit MEP - General
    Last Post: 2015-07-03, 11:52 AM
  2. 2013: Elevation Editor Jumps to Bottom of List after Editing Elevation Value
    By aspencer.226869 in forum AutoCAD Civil 3D - General
    Last Post: 2014-03-21, 07:01 PM
  3. 2013: How to import AutoCAD elevation drawing into Revit Elevation
    By akamildxb in forum Revit Architecture - General
    Last Post: 2013-05-29, 01:58 AM
  4. associating global elevation and building elevation on a single level....
    By olakahahola in forum Revit Architecture - General
    Last Post: 2007-11-07, 08:33 PM
  5. Replies: 9
    Last Post: 2006-08-24, 11:46 AM
