Results 1 to 10 of 10
Thread: script help
    2007-04
    Cincinnati
    36
    Default script help
    I'm trying to modify a script for setting text and dimension styles that i got from a previous employer. I wanted to change the font to country blueprint. Every time that I try to change the font the script ceases to work.
    one problem that i'm experiencing is that it has trouble distinguishing between shx and ttf fonts. the script my former workplace used just stated the name and didn't include extension (i think it defaults to shx) but I've tried to get it to work with country blueprint, but it doesn't seem to understand that it's ttf. If anyone has the shx font of country blueprint could they send it to me?
    Here's the other problem. When I change the font listed the script messes up. I'm not sure what all the returns (hitting enter) are for unless that resorts to default of question?
    Original script: (IGNORE ****** just trying to encapsulate the script to clear up confusion)
    -STYLE
    PS-TEXT
    HAND1
    .09
    PS-HEADERS
    OR-LD
    .1875
    PS-TITLES
    OR-LD
    .25
    MS-1-HEADERS
    OR-LD
    .1875
    MS-1-TEXT
    HAND1
    .09
    DIM
    DIMALT
    OFF
    DIMALTD
    2
    DIMALTF
    25.4000
    DIMALTTD
    2
    DIMALTTZ
    DIMALTU
    2
    DIMALTZ
    DIMAPOST
    DIMASO
    ON
    DIMASZ
    DIMAUNIT
    DIMBLK
    DIMBLK1
    DIMBLK2
    DIMCEN
    .05
    DIMCLRD
    BYLAYER
    DIMCLRE
    BYLAYER
    DIMCLRT
    7
    DIMDEC
    3
    DIMDLE
    .05
    DIMDLI
    .375
    DIMEXE
    .05
    DIMEXO
    .05
    DIMFIT
    5
    DIMGAP
    .025
    DIMLFAC
    DIMLIM
    OFF
    DIMPOST
    DIMRND
    DIMSAH
    OFF
    DIMSCALE
    DIMSD1
    OFF
    DIMSD2
    OFF
    DIMSE1
    OFF
    DIMSE2
    OFF
    DIMSHO
    ON
    DIMSOXD
    OFF
    DIMTAD
    DIMTDEC
    3
    DIMTFAC
    DIMTIH
    OFF
    DIMTIX
    ON
    DIMTM
    DIMTOFL
    ON
    DIMTOH
    OFF
    DIMTOL
    OFF
    DIMTOLJ
    DIMTP
    DIMTSZ
    .041666
    DIMTVP
    .8333
    DIMTXSTY
    MS-1-TEXT
    DIMTXT
    .09
    DIMTZIN
    DIMUNIT
    6
    DIMUPT
    OFF
    DIMZIN
    3
    SAVE
    ARCH-DIM-1
    DIMASZ
    .15
    DIMCLRT
    BYLAYER
    DIMFIT
    5
    DIMGAP
    .05
    DIMTSZ
    DIMTVP
    DIMUNIT
    6
    SAVE
    ARCH-LEA-1
    RESTORE
    ARCH-DIM-1
    EXIT
    splitting to 2 replies because the message gets far too long with the output
    2007-04
    Cincinnati
    36
    Default Re: script help
    I replace the font "hand1" with "romans" (for sake of argument since i cant get ttf fonts to work yet) and it produces this output
    Command: SCRIPT
    Command: -STYLE
    Enter name of text style or [?] <Standard>: PS-TEXT
    New style.
    Specify full font name or font filename (TTF or SHX) <txt>: romans
    Specify height of text or [Annotative] <0.0000>: .09
    Specify width factor <1.0000>:
    Specify obliquing angle <0>:
    Display text backwards? [Yes/No] <No>:
    Display text upside-down? [Yes/No] <No>:
    Vertical? [Yes/No] <No>:
    "PS-TEXT" is now the current text style.
    Command: PS-HEADERS
    Unknown command "PS-HEADERS". Press F1 for help.
    ANY IDEAS???? i'm clueless. for some reason the first script moves to the next -style command without typing it.
    I tried modifying the second string of commands as follows(added second -style command):
    -STYLE
    PS-TEXT
    romans
    .09
    -style
    PS-HEADERS
    OR-LD
    .1875
    Output:
    Command: script
    Command: -STYLE
    Enter name of text style or [?] <PS-TEXT>: PS-TEXT
    Existing style.
    Specify full font name or font filename (TTF or SHX) <romans.shx>: romans
    Specify height of text or [Annotative] <0.0900>: .09
    Command: -style
    Enter name of text style or [?] <PS-TEXT>: PS-HEADERS
    New style.
    Specify full font name or font filename (TTF or SHX) <txt>: OR-LD
    Specify height of text or [Annotative] <0.0000>: .1875
    "PS-HEADERS" is now the current text style.
    Command:
    -STYLE Enter name of text style or [?] <PS-HEADERS>: PS-TITLES
    New style.
    Specify height of text or [Annotative] <0.0000>: .25
    "PS-TITLES" is now the current text style.
    Command:
    -STYLE Enter name of text style or [?] <PS-TITLES>: MS-1-HEADERS
    New style.
    "MS-1-HEADERS" is now the current text style.
    Command:
    -STYLE Enter name of text style or [?] <MS-1-HEADERS>: MS-1-TEXT
    New style.
    Vertical? [Yes/No] <No>: DIM
    Yes or No, please.
    so by adding -style again the script hiccups and stops dead in its tracks. you have to hit return and it doesn't continue through to the next text style and subsequent dim styles
    AUGI Addict tedg's Avatar
    2005-06
    in the upper right corner
    2,287
    Quote Originally Posted by mark.momper View Post
    one problem that i'm experiencing is that it has trouble distinguishing between shx and ttf fonts. the script my former workplace used just stated the name and didn't include extension (i think it defaults to shx) but I've tried to get it to work with country blueprint, but it doesn't seem to understand that it's ttf. If anyone has the shx font of country blueprint could they send it to me?......
    The file name for Country Blueprint.TTF is "counb___.ttf"
    This is the script you want (edit it and add more names as needed)
    -style
    PS-TEXT
    counb___.ttf
    -style
    PS-HEADERS
    counb___.ttf
    -style
    PS-TITLES
    counb___.ttf
    -style
    MS-1-HEADERS
    counb___.ttf
    Note, there are (5) five <enters> between commands "entering" thought the defaults, if you need other than the defaults, you would edit accordingly. Also, to "finish" the script you need one more <enter> at the end (= 6 enters)
    Hope it helps
    Ted
    ____________________________________________________________________________________
    AutoCAD 2012 - REVIT Structure 2012 - MicroStation V8i - Windows 7 Professional - (dabble with Inventor 2012)
    2007-04
    Cincinnati
    36
    what would i do if i wanted to keep the dimension script on the end?
    when i edited the script to match yours i got this output
    Command: script
    Command: -style
    New style.
    Specify full font name or font filename (TTF or SHX) <txt>: counb___.ttf
    Command: -style
    New style.
    Command: -style
    New style.
    Command: -style
    New style.
    Display text upside-down? [Yes/No] <No>: DIM
    Yes or No, please.
    do i just need more enters?
    2005-06
    2,287
    Command: -style
    New style.
    Yes or No, please.
    Yes, you add an <enter> after Display text upside-down? [Yes/No] <No>:
    Are you adding a text style named "DIM"?
    Basically just keep repeating the pattern as you add different style names with (5) enters between them and simply add one more enter at the end of the script.
    Ted
    2007-04
    Cincinnati
    36
    The script as it used to work actually created dimension styles and leaders for each scale. I have the same script written for most architectural scales.
    so it's not a text style per se
    the unmodified script still functions perfectly, i just don't have the font to use anymore so i had to use one that i possess.
    Dim is just the command that starts the next string. i guess i can separate them into two separate scripts if necessary, but it's nice to have one script that gives you all the text used in a given scale as well as the dimensions and leader styles.
    2007-04
    Cincinnati
    36
    I just tried adding 6 <enter> between the end of the text script and the dim script and now it is trying to repeat the "-style" command
    apparently because enter again defaults to repeating a command.
    but with only 5, I get asked "Vertical? [Yes/No] <No>: -style
    Yes or No, please."
    2005-06
    2,287
    Are you saying you have a full script that works but you just need to change the font to Country Blueprint? You could use "find and replace" from <your old font> to "counb___.ttf"
    Or if you use the one you're working on, just make sure you add the <enter> to finish the -style routines and go into the dim routine.
    You could
    Ted
    2005-06
    2,287
    If you're adding the "DIM" routine to the end, keep only 5 enters.
    Ted
    2007-04
    Cincinnati
    36
    tedg, thanks for all the help. i guess i understand it a bit better.
    for some reason when i was replacing the old font i must have eliminated an <enter>
    when i did "find and replace" it worked fine.
    Thanks for all the help.
    if anyone wants the script here's the working version for one of the scales. you just would have to edit it to match your preferences for tics and font, size etc. it's set in inches default
    -STYLE
    PS-TEXT
    counb___.ttf
    .09
    PS-HEADERS
    OR-LD
    .1875
    MS-2-TITLES
    OR-LD
    .5
    MS-2-HEADERS
    OR-LD
    .375
    MS-2-TEXT
    counb___.ttf
    .18
    DIM
    DIMALT
    OFF
    DIMALTD
    2
    DIMALTF
    25.4000
    DIMALTTD
    2
    DIMALTTZ
    DIMALTU
    2
    DIMALTZ
    DIMAPOST
    DIMASO
    ON
    DIMASZ
    DIMAUNIT
    DIMBLK
    DIMBLK1
    DIMBLK2
    DIMCEN
    .05
    DIMCLRD
    BYLAYER
    DIMCLRE
    BYLAYER
    DIMCLRT
    7
    DIMDEC
    3
    DIMDLE
    .05
    DIMDLI
    .375
    DIMEXE
    .05
    DIMEXO
    .05
    DIMFIT
    5
    DIMGAP
    .025
    DIMLFAC
    DIMLIM
    OFF
    DIMPOST
    DIMRND
    DIMSAH
    OFF
    DIMSCALE
    2
    DIMSD1
    OFF
    DIMSD2
    OFF
    DIMSE1
    OFF
    DIMSE2
    OFF
    DIMSHO
    ON
    DIMSOXD
    OFF
    DIMTAD
    DIMTDEC
    3
    DIMTFAC
    DIMTIH
    OFF
    DIMTIX
    ON
    DIMTM
    DIMTOFL
    ON
    DIMTOH
    OFF
    DIMTOL
    OFF
    DIMTOLJ
    DIMTP
    DIMTSZ
    .041666
    DIMTVP
    .8333
    DIMTXSTY
    MS-2-TEXT
    DIMTXT
    .09
    DIMTZIN
    DIMUNIT
    6
    DIMUPT
    OFF
    DIMZIN
    3
    SAVE
    ARCH-DIM-2
    DIMASZ
    .15
    DIMCLRT
    BYLAYER
    DIMFIT
    5
    DIMGAP
    .05
    DIMTSZ
    DIMTVP
    DIMUNIT
    6
    SAVE
    ARCH-LEA-2
    RESTORE
    ARCH-DIM-2
    EXIT
  1. Script Help
    By geoffrey.m.reynolds in forum AutoCAD Customization
    Last Post: 2012-03-20, 10:24 AM
  2. Script pro
    By plarson.118418 in forum AMEP General
    Last Post: 2008-12-18, 06:30 PM
  3. Need a script to (xx)
    By aharris in forum AutoLISP
    Last Post: 2008-08-22, 05:42 AM
