Results 1 to 6 of 6
Thread: Utilizing math functions [f(x)] to generate sketch geometry.
    2006-11
    Houston, Texas
    7
    Question Utilizing math functions [f(x)] to generate sketch geometry.
    We have parts with complex shapes which can only be defined by generating a curve based on a mathematical equation. For example: sine wave, parabola, hyperbola, etc. How can we command inventor to generate a sketched shape such as this?
    Turlock, CA
    6,420
    Default Re: Utilizing math functions [f(x)] to generate sketch geometry.
    I don't have IV anymore, so I can't give you specific help on the newer versions. However, I have a lisp routine that will generate a parabola. IOW, you can run the function in acad, generate a polyline, and then import that into IV and loft it, sweep it, etc.
    C:> ED WORKING....
    LinkedIn
    2006-11
    Houston, Texas
    7
    Thanks for the quick reply Ed. If you wouldn't mind sending me that lisp file I'll give it a try. At least it will give a place to start.
    I'm new to this whole forum thing. Can you get my e-mail from my profile?
    2008-01
    Where the railroad meets the sky
    47
    From what I gather you have to draw the geometry and then apply equations to drive dimensions you'd put in.
    Take for example a parabola...
    Draw a spline with 3 points. Dimension between the 3 points in a matter that permits the lateral distance to be equal from each endpoint to the centerpoint, and then apply your height dimension...
    Like this...
    Turlock, CA
    6,420
    In case you still want the lisp.
    C:> ED WORKING....
    LinkedIn
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    Another suggestion, use Excel to generate the points, and import the points into Inventor. You should be able to put a spline through that and get your curve.
    Don't know if that absolutely solves your issue, but it's at least another option.
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
  1. 2012: Looking for a listing of math functions usable in Families Editor...
    By ccenergy in forum Revit Architecture - Families
    Last Post: 2013-06-28, 10:41 PM
  2. Redefine sketch not breaking projected geometry
    Last Post: 2012-09-26, 10:45 AM
  3. Want to Generate Slope Symbols OUTSIDE the Roof Sketch Boundary
    By layneruley in forum Revit Architecture - General
    Last Post: 2009-07-06, 02:58 AM
  4. Drawing lines to match math functions.
    By larryp.125211 in forum AutoCAD General
    Last Post: 2006-10-26, 08:59 PM
