Thread: 2d horizontal section door display
    2008-02
    2
    Smile 2d horizontal section door display
    When I generate a 2d section, the doors always appears closed; it does not matter if the swing angle is 90 or 45 or zero.. they always appears closed in the section.
    What can i do to display them opened?
    ACA Community Director dkoch's Avatar
    2003-03
    Going for a long walk off a short pier
    1,862
    Default Re: 2d horizontal section door display
    Quote Originally Posted by torreskax View Post
    Edit the Display Representation for doors that is active in the Display Representation Set that you use when generating the 2D Section/Elevation object, and, on the Other tab, either uncheck the Override Open Percent toggle (if you want the Properties palette value to govern) or change the override amount to something other than zero. Note that here, the opening amount is given in terms of percentage, but on the Properties palette, the value is in terms of swing angle. 100% open is the same as a 180-degree swing angle (or PI radians, if that is your preferred angle measure unit).
    David Koch
  1. Horizontal position of door frame when inserted into wall
    By b.boyes in forum Revit Architecture - General
    Last Post: 2009-11-16, 12:03 PM
  2. Section View Horizontal Offsets
    By thair in forum AutoCAD Civil 3D - Sections
    Last Post: 2008-11-04, 01:53 PM
  3. section horizontal inaccuracy
    By dgi in forum ACA General
    Last Post: 2008-03-24, 11:49 AM
  4. Section Box will not display
    By Davied2 in forum Revit Architecture - General
    Last Post: 2005-10-24, 12:38 PM
  5. Section Detail Extents horizontal adjustment
    By karl.87950 in forum Revit Architecture - General
    Last Post: 2005-06-08, 12:55 PM
