Hi,
I have had a problem in AutoCAD - when I for example switch between model space and paper space or between 2 dwg files the whole screen freezes - sometimes up to 7-8 sec. I have tried to see if it is on just some files or older dwg files etc etc but I have not been able to narrow it down to anything specific that would cause it. That is why I lean towards it might be a graphic card issue (or setting). My boss is getting very frustrated and told me to get a "bloody new graphic card" as every time I need to show him something on the screen the freeze thing happens. This happen both on AutoCAD 2007, 2008 and also Autocad2006LT.
I am moving more towards using Revit (working on my first major project now) but will still be working with AutoCAD as everyone ells in the office (at this stage) is using it. I have been browsing through the forum and it seems that a FireGL card is the way to go.
Sometimes when I zoom in annotations etc is disappearing but it is not consistent ie it is not happening all the time. I run Revit in OpenGL mode and followed Wes and David's recommendations for the settings.
I guess my questions are firstly: the problem I have with AutoCAD do you think it could be related to the graphic card or could it be something ells? Are there any tests I can run to be certain if it is the graphic card?
Secondly: Are there any known compatibly problems between motherboards and graphic cards? If I get any PCI-e card it will work with my motherboard or are some cards working better with some motherboards?
ASUS P5VD2-MX
2.5 GB RAM
WIN XP
GeForce 7300 LE 256MB/128MB GDDR2
Thanks for any suggestions.
Jonas
