Thread: Central file is inaccessible error message
    2004-10
    Yorkshire, UK
    402
    Default Central file is inaccessible error message
    Does anyone every get the following error message despite the network being available:
    "Cant obtain permission to edit the elements the central file is inaccessible, you can check out the worksets at risk, but consider carefully!"
    This seems to be happening on some of our machines regularly, but not on others.
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Central file is inaccessible error message
    If the Central file hasnt been deleted or moved it looks like a network issue.
    2004-10
    Yorkshire, UK
    402
    We are upgrading the office in question to RAC2008 SP3. I will see if this makes any difference.
    I have read somewhere on Augi that Revit has problems with RAID5 hard disks (which our server uses) and wonder if this may be the issue.
    2005-07
    3,792
    Yeah, that's in my best practice documents, seems like STC is an issue with some RAID config and NAS
    2004-10
    Yorkshire, UK
    402
    It seems ridiculous if Revit has problems with RAID 5 arrays as these are so common place - are support aware of this potential problem (I dont have access to support at the moment)?
  1. "Other Users have saved changes to the Central File"..Error Message
    By kmarquis in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-04-05, 02:06 PM
  2. central file inaccessible error message
    By sami in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-05-28, 05:45 AM
  3. Local File Incompatible with Central File - Revit 2010 Error??
    By ekneer in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-02-18, 03:51 PM
  4. Central File Error Message
    By dsw98 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-02-25, 03:43 AM
  5. Error Message w/ workset Saving to central
    By Baldwin_4-6-0 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-03-11, 12:55 AM
