Results 1 to 10 of 12
Thread: Edit Time per Lynn Allen
    Member markm.66285's Avatar
    2004-03
    North Coast of Ohio
    10
    Question Edit Time per Lynn Allen
    Good day!
    I received Lynn Allen's "Top 10 Tips for AutoCAD 2005" tip book and noticed there is a mention of EDIT TIME. I tried to this, but it seems to pop up a DOS window and somehow this just doesn't seem right so I backed out of the command.
    Does anyone know what this is and how to properly utilize this to track my time per drawing?
    Thanks!
    2001-03
    13,499
    Default Re: Edit Time per Lynn Allen
    Hi Mark
    Please note I've *moved* this thread from the ACAD 2005 Wish List Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    150700
    3,421
    Judging by what you typed, you put a space in between edit and time. By doing that, you are running the edit command on a file named "time"
    Try typing EDITTIME, with no space. That should work
    2001-03
    13,499
    Hi
    As far as I'm aware there isn't such a command as EDIT within AutoCAD (but I could be totally wrong here).
    Are you referring to the following snippet from Lynn Allen's "Top 10 Tips for AutoCAD 2005" -
    <snip>
    EDIT TIME (new to AutoCAD 2005)
    Want to keep track of your actual
    drawing time (and billable hours)?
    EDITTIME to the rescue!
    </snip>
    If yes, have a browse through the 45 results obtained for "EDITTIME" on the Autodesk Discussion Groups (hopefully one or two of them may help a little) -
    "EDITTIME" in "All AutoCAD Groups" found 45 results
    Have a good one, Mike
    2001-05
    Austin, TX USA
    2,201
    When you type in edit at the command promote, you get the MS-DOS editor. When I type the EDITTIME command and hit F1 it pops up with the express tool help.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2001-03
    13,499
    Quote Originally Posted by gpope
    Hi
    Is only true if it's been defined as an External Command within the Acad.pgp file.
    2001-05
    Austin, TX USA
    2,201
    By default it must be. I'm using the standard pgp file with only a few added alias. I didn't add any for the MS-DOS editor.
    Glenn Pope
    Windows 7 Pro 64bit
    I explode MTEXT.
    2001-03
    13,499
    Hi Glenn
    That could well be the case, I don't use the default Acad.pgp file.
    Might be splitting hairs here but I was only trying to point out that EDIT is not an AutoCAD command.
    Mike
    150700
    3,421
    When I type edittime, this is what I get. Also, when I type edit, it does pop up a dos box (see other attached drawing)
    2004-03
    North Coast of Ohio
    10
    When I type, EDITTIME, I get nothing except a prompt to hit F1, which then takes me to the help window. If I type, EDIT, I get a DOS window. Strange....... maybe this doesn't work??
  1. Lynn Allen and Dallas CAD Camp
    By lswinea in forum Local User Groups - General
    Last Post: 2010-04-23, 11:44 AM
  2. Lynn Allen To Visit Dallas 5-11-09
    Last Post: 2009-04-30, 04:11 PM
