Ok,
So now, I am creating custom plumbing fittings / valves. Should be a straight-forward process, yeah?
I was able to modify an existing block for a particular fitting. Simple: 'bedit' the block.
But what about when I want to create a custom fitting? I copy the style that is similar to the fitting I want. I rename it. I point to the new block. But wait, where did the block come from? I inserted the block pertaining to the style that I copied. I explode that, and define a new block, I make sure that the new block is 'unitless', but still, when I use this fitting, it comes in one-twelfth as big as it should. This is regardless of whether I have chosen 'inches' or 'unitless' or 'feet' for the "unit" of the block definition. What gives?
Surely, this is an easy one!
Paul
