Results 1 to 6 of 6
Thread: What is the variable for sheet set template file location?
    2003-11
    450
    Default What is the variable for sheet set template file location?
    I know how to set it. It is under Options -> Files -> Template Settings -> Sheet Set Template File Location, but I would like to set it automatically.
    I would also like the variable for "Default Template for Sheet Creating and Page Setup Overides".
    Thanks
    2004-08
    Iron Station, NC
    3,198
    Default Re: What is the variable for sheet set template file location?
    I was able to find the following
    (setq AcadFiles
             (vla-get-files
               (vla-get-preferences
             (vlax-get-Acad-Object)
               ) ;_ end of vla-get-preferences
             ) ;_ end of vla-get-files
          ) ;_ end of setq
    (setq TemplatePath (vlax-get-property AcadFiles "PageSetupOverridesTemplateFile"))
    I couldnt find a command to set the SheetSet Template Folder Path. the above will return the current path, to set it do the following
    (vlax-put-property AcadFiles "PageSetupOverridesTemplateFile" TemplatePath)
    2001-10
    Defragging the internets.
    350
    (GETENV "SheetSetTemplatePath");To find current location
    (SETENV "SheetSetTemplatePath" "U:\\Template");To set new location;note the double \\
    Chris
    PS,
    To find this I set my template folder to "C:\find-me" and then searched my Registry for the "find-me" folder.
    2008-03
    Thumbs up Re: What is the variable for sheet set template file location?
    Hi,
    Not sure if the prior solutions are the simplest.... this is what i use in my acaddoc.lsp to ensure paths are (and stay) correct :
    (setenv "PrinterStyleSheetDir" "ctbpathhere")
    (setenv "PrinterConfigDir" "pc3pathehere")
    (setenv "PrinterDescDir" "pmppathhere")
    (setenv "TemplatePath" "dwgtemplatepathhere")
    (setenv "SheetSetTemplatePath" "sheetsettemplatepathhere")
    (vla-put-QNewTemplateFile (vla-Get-Files (vla-Get-Preferences (vlax-get-acad-object))) "qnewtemplatepathhere")
    (vla-put-PageSetupOverridesTemplateFile (vla-Get-Files (vla-Get-Preferences (vlax-get-acad-object))) "psotemplatepathhere")
    -- remembering that paths have a \\ eg.
    "J:\\AUTOCAD\\SUPPORT"
    2007-02
    Calgary, Alberta, Canada
    73
    Quote Originally Posted by msanmarzano View Post
    Hi,
    If I type (getenv "ToolPalettePath"), it tells me that the path is on the C:/.
    When I type (setenv "ToolPalettePath" "J:\\CAD\\Tool Palettes"), it tells me that the path is J:\\CAD\\Tool Palettes.
    Now, when I go into Options or open my Tool Palettes, it's still the ones on the C:/, even after I restart AutoCAD. What am I missing?
    2008-06
    Rochester, NY
    109
    FRAMEDNLV, if you are ever in the Rochester, NY area, let me know, I need to buy you a beer. Your short little post probably just solved 75% of my AutoCAD problems and/or headaches!
  1. Sheet Set Template File Location in c#
    By oakam430373 in forum RealDWG
    Last Post: 2017-09-04, 01:47 AM
  2. Template file location
    By gadjet in forum CAD Standards
    Last Post: 2009-12-04, 07:50 PM
  3. Is there a variable by which I can get font file location?
    By rajat_bapi_mallick in forum AutoLISP
    Last Post: 2007-05-24, 05:51 PM
  4. Open Template file from a Network location
    By drafting.82475 in forum AutoCAD Customization
    Last Post: 2005-07-29, 04:04 PM
