I have a window family which has several casing families nested into it. The family loads fine, the casings swap as intended and the entire family cuts in plan and section as expected.
The problem arises when a window type is loaded which is short enough in height so that the bottom edge of the casing is above 4'-0" A.F.F. Of course if the cut plane is at the default height of 4'-0" A.F.F. then the window will not display much less be cut. So I add a plan region and set its height to 6'-0", for example, and the window displays cut, but the nested casing displays as though it is entirely below the cut plane. The same problem occurs if I change the cut plane of the view to 6'-0". When cut in section, the entire window family and casing displays properly cut.
