Results 1 to 10 of 11
Thread: Not able to plot all viewports
    2004-08
    30
    Angry Not able to plot all viewports
    My problem is not being able to plot out everything in all my view ports. The only one that will plot is the last view port generated. I can edit objects in these view ports and adjust them as needed but I can't plot them. There must be a setting that manipulates this but I can't find it. I have checked to see if any setting were clicked for hide features. I know it isn't something specific as something wrong with a specific view port, because when I add another that one is the one that is shown.
    Another problem that I am having with plot is that I have all of my settings in plot setting to plot everything to plot in black. When I go to plot, the drawing plots in color. I have checked all the settings don't know what else to check.
    I am thinking that both of these problems are toggle setting in the program. Both problems are displaying the same in print preview as they are plotting.
    2001-03
    13,499
    Default Re: Not able to plot all viewports
    Hi
    1. Floating Viewports - Does this problem occur in only 1 drawing file or all drawing files?
    2. Plot Black & White - ID: TS31447 - Plot all objects black regardless of output device
    What version of AutoCAD are you using?
    Have a good one, Mike
    2004-08
    30
    Red face Re: Not able to plot all viewports
    Hello
    Yes we are using floating view ports. It doesn't happen in all files. We are using Autodesk Architectural Desktop 2004. All black setting are being used as far as plotting settings. I appreciate your help.
    Louis
    2001-03
    13,499
    Hi
    Could you please post one of your "problem" drawing files + the Plot Style Table (CTB or STB) + the Plot Configuration File (PC3) being used to Plot the "problem" drawing file.
    0,0,0 The Origin
    8,027
    What's the setting for MAXACTVP ?
    As I recall, the default is 48 but a setting of 1 would give the effect you describe.
    John B
    2001-05
    Austin, TX USA
    2,201
    MAXACTVP System Variable
    Type: Integer
    Saved in: Drawing
    Initial value: 64
    Sets the maximum number of viewports that can be active at one time in a layout. MAXACTVP has no effect on the number of viewports that are plotted.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    2001-03
    13,499
    Hi
    For more information on the system variable MAXACTVP check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS69897 - New viewports are blank or colors are incorrect when number of viewports nears value of MAXACTVP
    ID: TS42133 - Unable to use plot styles to plot saved views
    ID: TS21414 - Geometry in paper space viewports disappears
    ID: TS66973 - Unable to apply plot style to multiple viewports
    2004-08
    30
    Unhappy Re: Not able to plot all viewports
    All my setting are set to a black plot. It is still plotting in color. It is only doing this on my computer. All other computers that I access the same files are to the same setting(apparently). I don't think it is a problem with the file specificly. Thank you. By the way the view port problem was corrected.
    2001-03
    13,499
    Hi
    Quote Originally Posted by nanoaguilar2000
    I think you really need to confirm this 100% before looking at other possible reasons.
    Just out of interest and education (for myself) what was the problem?
    2004-08
    30
    The problem with the viewports was just a glitch with the computers. Could you think of an answer for the "plotting in color" problem?
    Louis
  1. Multiple viewports and plot styles
    By KLA in forum CAD Standards
    Last Post: 2008-09-25, 07:26 AM
  2. viewports will not plot
    By ABERGMAN in forum AutoCAD Plotting
    Last Post: 2008-07-17, 04:26 PM
  3. Lineweights in Floating Viewports Plot light...
    By jeff.garr in forum AutoCAD Plotting
    Last Post: 2007-01-04, 01:53 PM
  4. Plot Files and Viewports
    By jperrotta in forum AutoCAD Plotting
    Last Post: 2004-09-09, 12:17 PM
