Results 1 to 8 of 8
Thread: line break for a field?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,324
    Default line break for a field?
    I want to a field to tie the project name fro the Sheet Set Manager to the project name in the title block to be included in a series of drawings. However, the project name is long. Is there a way to put some kind of symbol in the project name in the properties dialog box of the sheet set -- something that the field would recognize as a line break? The field is in a piece of mtext.
    Autodesk Civil3D 2018, Revit 2018
    Gig 'Em, Aggies!
    Earth
    9,534
    Default Re: line break for a field?
    Quote Originally Posted by Maverick91 View Post
    You will have to create "X" number of custom properties and break up the project name into "X" number of strings.
    Then link these custom properties to "X" number of fields.
    R.K. McSwain | CAD Panacea |
    I could stop if I wanted to SRBalliet's Avatar
    2004-06
    Near Christiansburg, VA Looking for a closer job!
    499
    The only way is to place your field and then assign it a "Defined Width" in the Properties Dialog box under Text. The text will wrap in the defined width but you have no control of where it breaks the line. You can't put in a hard return.
    If you can't live with that you need to use R.K. McSwain's way.
    Steve Balliet
    Craig Co., VA
    Civil 3D, Mechanical 2012
    Earth
    9,534
    Exclamation Re: line break for a field?
    Quote Originally Posted by SRBalliet View Post
    Good point. I thought that was assumed, but after re-reading the OP - it's good that you pointed that out.
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    text fields will work, but they can't be embedded in a block
    S&D DB Sharing Forum
    2016-01
    4
    Another way is when you type in the Project Name information in the Title field, insert the number of spaces where you would like to have a line break then in the drawing use grips to vary the width of the mtext and you will then have your different lines of text as required.
    2008-04
    2
    Quote Originally Posted by glen.mccarley View Post
    The problem with this method is that, if you're also using the sheet set to produce a drawing index, the spaces will appear in your drawing description here as well. Difficult to find a way that brings them all together automatically, rather than having to "tweak" each location to get consistent formatting.
    Just sayin...
    Cairo - no, not Illinois
    4,698
    Just as a random bit of inconsistency ion the way AutoCAD handles fields,,,, if the fieldd is pointing to DWGPROPS, then a hard return actually does work.
  1. Annotation - Dynamic Break Line (dyn-break)
    By Kernal_CAD_Monkey in forum Dynamic Blocks - Technical
    Last Post: 2012-07-30, 11:28 AM
  2. Annotation - Dynamic Break Line (dyn-break)
    By barry.40197 in forum Dynamic Blocks - Sharing
    Last Post: 2011-01-13, 03:41 AM
  3. Line Based Break Line
    By djn in forum Revit Structure - Families
    Last Post: 2008-11-24, 07:55 PM
  4. line break in a field?
    By Maverick91 in forum AutoCAD Fields
    Last Post: 2008-03-04, 12:24 AM
  5. break a line
    By kap_78 in forum VBA/COM Interop
    Last Post: 2005-10-04, 02:34 PM
