I'm making window and door families for log walls, where the window is attached to a nailer that is attached to a log buck. Andre helped me get a void in the window family that would cut the opening in the log wall when inserted in the project. I want the nailer to be a standard frame wall thickness (6 1/2") and my log wall has a 9" core with log sweeps for a 16" diameter log.
I can't figure out how to disassociate the window family from the wall so I can change the wall to 9" and maintain the window in a 6 1/2" nailer dimension. The way I did the first one was to change my wall to 9" and then unlock everything and then reattach all of the parts and pieces back to reference planes at the 6 1/2" dimension. This becomes very time consuming to get every thing in the right position and locked so everything flexes properly.
There's got to be an easier way?
